AFH Head, AVY/AFH Engine Parts, Megasquirt 1 ECU, AFH 4-2-1, GT Engine
GT Engine - £200 ono doesnt not come with ecu or loom, just engine with inlet manifold ect
I also have a knife edged crank for a 1.6 16V (AVY) Polo GTI engine
Looking for £200 but will listen to reasonable offers.
standard AFH head forsale with no cams £150 ONO
AVY Rods and Pistons x 4 £80
EFI EXTRA MS1 ECU Fuel and Spark Control
4 Injector outputs
2 Spark outputs for a wasted spark ignition setup
Can be used with VR or Hall sensor for trigger
Air temp sensor
Water temp sensor with adaptor for polo coolant junction
AVY/Polo GTI inlet manifold with correct thread for MS air temp sensor
£300 all in for everything this would cost £335 for just the ecu new, the sensors would be another £30 on top of this plus there is the manifold thrown in too, I can also help the buyer with intial setup (wiring diagrams and connector information, basic settings for running and anything else you may wish to know)
AFH cambelt kit fitted but barely used, tensioner and relay roller in good condition along with the waterpump.
relay roller pre-drilled for use on AVY block.
£70 ONO
AFH 4-2-1 Stainless Steel Manifold £100 ONO
Can post at buyers expense
Lots of other AVY/AFH engine parts just ask!
Edited by forbes-1234
  • Replies 39
  • Views 2.4k
  • Is it in full working order pal? Will you do the head and timing kick for 150? Cheers
Have you got an afh conversion loom?
Do you have a head for an avy engine? I'm also after the breather hose if its any good.
How does the megasquirt work with the vvt on an avy ?
It can be made to work with it yes, it is currently not setup for it but phil at efi extra will be able to help you out with this if you emai/call him.
AFH 4-2-1 fit on a avy?
Do you have the pipes for the oil cooler?
Still got loads of engine parts message me for details of what you would like, I will most probably have
you got a proper trigger wheel ect for the megasquirt? on my 16v the standard trigger wheel is just randomly slapped on and the casting for the sensor is snapped so i cant use it
Nah man I used 60-2 standard gti trigger but you could knock up a bracket and trigger wheel and us a vr sensor if you wish
damn. do you know how to set up the 60-2 wheel on the avy? would be easier to get a new casting and use that i suppose. £300 your best price also?
just seen this mate sorry!
it can be set-up in various different ways the main two are using a trigger offset angle or setting up the trigger with a time based offset.
£300 is my best price for everything together.
if you didnt want certain parts then we could sort something out I suppose
BUMP!
Loads of MK2F parts available ask for what you need!
What's the mileage on the GT engine? And dies it include the dizzy and stuff?
pretty sure it was on about 80k when it was pulled out years ago
the dizzy is there but the connector is broken, it is literally the engine!
Do you have any pics of the crank and manifold? Do you have a price for the crank, rods/pistons and mani?
Matt
do you still have the afh manifold?
do you have an AVY/ARC Flywheel?
still have the head??
bump
still got standard head
block
standard crank, pistons and rods
megasquirt setup
gt engine
cheapest price on head mate really need one and your local??
cheers
sam
£100
Cambelt kit sold?
cambelt kit still available!
