Polo 6n Rear Wiper Nut Size
Hi...
Does anybody know the size of the nut the holds the wiper motor onto the bootlid?
I know there are several, but I'm referring to the larger one on the outside of the car, under the actual plastic wiper cover.
I suspect it will be 15-16mm.
I'd like to buy the appropriate spanner on the way home tonight, rather than go home, measure it and then go out again.
Besides everything will be closed by then anyway.
Can anybody help?
Many thanks.
Edited by PoloMM
  • Views 984
It's a M8 nut so it should be 13mm spanner
Not the one that holds the wiper on. That would be close to 13mm as you say.
I'm referring to the large one that holds the actual motor on via the spindle sticking out the boot.
I think it would be closer to 18mm now I think of it.
OK that's a M16 nut so it should be a 24mm spanner
Legend. Thanks mate.
