Rotten battery tray
So Iggy failed the mot on one worn ball joint and insecure battery.
Its rotten around the clamp bolt hole. Most of the rest SEEMS ok, but i don't have a welder or any sheet steel, so how can I fix it enough to get it through the retest?
Thanks peeps.
  • Views 711
  • Drill a hole in the tray behind the battery, put a bolt through it, and drill another hole in front of the battery and do the same. Get a strip of metal long enough to reach from this bolt, over the
Get a strip of metal long enough to reach from this bolt, over the battery and to the other bolt.
Drill a hole in each end of the metal strip and then fix these to each bolt/stud.
Did the trick for my mot, I welded my tray but the back support panel for the battery was rotten.
Yes that's an arb bush.
Edited by derskine
Awesome job Mr.
Just looked up behind pedals............feck!
Had enough good metal to drill another clamp hole next to the old one. Put a big washer on the clamp stud and its good (for now)
As long as it isn't massively insecure it'll be alright.
