MK2 Dash into a MK2F/3. difficulty? What would be required?
As per the title, how hard is it to fit one and what other mk2 bits would need to worked out for it, ie heater unit etc.
  • Views 876
Not hard to fit in, but why would you want to back date your car? The most complicated part will be changing the wiring over, the switches will use different connectors etc, i know the clock wiring plugs are different. Mountings are the same, heater box is the same.
Would the Mk2 dash foul the Mk2f door cards?
i have a full mk2 dash loom...
I really like the simplicity of the mk2 unit! And mk2 door cards are required but that isn't an issue.
