Attaching arch trims with no rivets
Want to put arch trims back on my GT but have rolled the arches to get the wellers to fit.
What kind of adhesive have people used to keep them on without rivets?
  • Replies 11
  • Views 937
No Nails or Silicon ??
Sikoflex is what you need or Tigergrip automotive variants of what Nige speaks of.
Any auto factors or paint supplier will stock it.
I did mine today with tigerseal. Get some latex gloves or you'll get very messy!
I sanded both surfaces thoroughly with 120 grit sandpaper, then just applied a thick bead of tigerseal and clamped the arch up with G clamps (some plastic clamps would be better as they are lighter)
Get ready with a rag and some white spririt to wipe away any excess. I left mine clamped up all day and they're now absolutely solid and won't be falling off any time soon!
I bought some tigerseal a while back for the purpose and forgot about it, so will give that a shot this weekend.
I'd give it wipe over with pannel wipe or simelar too just to make sure its fully degreased and any polish is removed..
used sikaflex on mine. no need to sand the panel back? lmao the hard part is getting the shit back off!
Obviously it will stick better if you sand the panel...
Edited by mk2coupe
mk2coupe it just needs degreasing man honest.......
You can't deny it will stick better if it's sanded... I understand that degreasing will let it stick, an probaby be strong enough, but flatting the surfaces will improve the adhesion.
I did it on mine because of how hard the ride is as the fact that my car spends it's time on back roads haha, I needed all the adhesion I could get.
Won't need to worry about polish on my car haha.
Giving it a key is a good idea though, everything that can help it stick should be used - it's not like my car is a shiny trailer queen anyway.
Edited by derskine
Done this only today with a starchem version of tiger seal.
No need to sand the panel it will stick plenty good enough.
1 of mine was a tad twisted, if thats the case just let something 'lean on it over night'
