Fitted open air to 6n2 advise
As above really, after info of anyone that has done it or has an open air.
Basically want to fit one in, not bothered about wiring etc I can do it easy. Fitting would be done at a bodyshop as roof would need cut and I don't want to fuck it up.
So my question, would the roof need any extra support adding in? I only ask as places such as webasto sell there version of the open air kit yet say nothing of extra support etc. I'm thinking it could affect the structural integrity of it but unsure
Thanks in advance for any help
  • Views 1.2k
this used to be done many a time back in the day, doubt it would need extra support, best thing would be look in an open air!! i like the idea of open airs there just a cool factor
i have done quite a bit of research into this as i was planning on doing it to mine (because they're awesome), but i have scrapped that car and so I'm now looking for a cheap open air (already fitted) to put all my nice parts onto.
basicly you need to take the windscrean out, and remove the boot. then drill the spot welds out along the gutters and windscrean frame and along the top of the boot. then outer skin should come off, might be attached around the folded seem around the opening, but would be a case of drilling more spot welds.
then the cross bracing need removing. same story, drill them out.
if your having someone fit it, then your best getting the entire roof section chopped at the pillars, and carefully remove the wiring before chopping. that way they can set it by the car and fit it exactly as it comes off.
as above this was regular work back in the day, not so much now though.
as for holes in the roof etc i have a friend that imports hoods and fits them and apparently they can get hold of most of the parts, so i imagine that most hood places can too.
Cheers guys, will see what my bodyshop want to do it
