New MkII owner...
Hi,
Bought a mk2 1990 1043cc.
Having problems getting used to driving an older, smaller car.
I'm OK with the steering and brakes but am having difficulty with the mirrors and seat.
The mirrors are dead flat meaning only a limited view and not the wide view that makes it so easy to see where you are in relation to items that are not that close to you (yet). I realise this is just as I've been spoilt for some time but am finding it really hard to get my head around... currently ignoring mirrors and just looking over shoulder instead.
Any one recommend some mirrors with convex lenses that will filt? (don't need to look original but must not look like they have been stolen from a lowered, stickered car with wide wheels - I'm far too old for that)
The leg room simply isn't enough, need to stick knees sideways when using the pedals. Dont mind only taking legless passengers on the right rear seat. Can the seat frame be moved back or is there a different seat that can be used to gain leg room?
Also made a mistake about the type of ignition it had - will be posting that one elsewhere - should have viewed the car before buying it!
Thanks in advance
K
  • Views 839
  • VolksKid83
    VolksKid83
    Could you get away with one of those little stick on wide angle mirror things on each mirror? Other than that, they didn't do curved mirrors, although i'm pretty sure my passenger side mirror has dist
Could you get away with one of those little stick on wide angle mirror things on each mirror? Other than that, they didn't do curved mirrors, although i'm pretty sure my passenger side mirror has distorted giving this effect!
What mirrors have you got currently? Non remote adjust or remote adjust? The latter could improve things or try and find some early Mk2 Derby wing mirrors which are longer, but also rare and desirable so not cheap!
As for the seats, how tall are you? I'm 6ft 3 and i fit well without the seat all the way back, knees are at angles but you get used to it. Does your drivers seat have height adjustment? Corrado or Scirroco front seats are a straight fit and sit lower do should improve things. If you get Mk2 Rocco GTII front seats with a Mk2f Polo Genesis rear bench they match perfectly too.
Hi Vk,
Thanks for the info.
Yes, the seating is a knee angle problem. Left is OK as I can get foot under/past pedals. Right is contorted back on itself at a painfull angle (ex-biker with bits missing and bits of road added).
More adjustment would be nice but I cant go 'up' as there is only about 20mm above my head now. Only option I can see is to go back further but struggling to see how to do this, perhaps I could re weld the seat brackets to the runners and get an extra 50mm?
The current mirrors are non adjustable - thats OK but the limited (flat) field of view is going to take some getting used to. I was hoping there was a modern (convex) mirror that would fit - looks like it will have to be those stick on 'wide angle' thinggies - Ebay and waiting on China post again.
Thanks for all the info, I'll post back if I resolve the seat issue - if not its time for a polish and a 'for sale' sign.
K
Is your seat all the way back?
And your mirrors should still adjust, only you move the head of the mirror with your hand, it might be worth trying the remote mirrors.
Hi Vk,
Yes the mirrors adjust fine - I'm just having trouble getting used to flat glass and would have liked modern ones but I can see thats not simple. Stick on blind spot mirrors it is!
The seat is all the way back - there is about 6" between the back of the seat and the passenger seat.
I'll have the seat out this weekend and see if its possible to move the bracketry.
Thanks again.
Keith
You can buy wide-angle lenses for other cars, you'd just stick one over your current lens using double sided padding on the flat section.
Getting one an identical size and shape wont happen but trace yours out on a piece of paper, cut it out so you have a template, and you could go to a shop like Halfords where a wide range is on display and find a very close match that will sit well enough.
This is the kind of 'outside the box' thinking you need to adopt when running a car like that..
