Could this be the end?
I have put my car in for it's mot today and basically just been rung by the garage to tell me it has failed. Reason being two front tyres and a cracked air pipe not to worried about them. But the bad news is they suspect my head gasket could of gone :(.
Does anyone happen to know how much a head gasket replacement would be on a polo 9n 03 plate? They said it could be 500-600 not sure if it's worth doing to the car or just get rid of it would be sad to see it go.
  • Replies 8
  • Views 834
  • SuperMario
    SuperMario
    Might as well of gone in there, dropped your pants and told them to take turns. Jesus don't mug you self off! It has a pre and post lambda, you can read them on a basic diagnostic machine too see if
Did you just book the car in for mot or for more work to be done. And how did they come to the conclusion the head gasket has gone. How long you had the car have you ever had any over heating problem or water loss.. And £600 doesn't sound to bad but if you got a good friend you could ask them nicely .
I booked the car in for the mot and now they have found out it's not the headgasket. It's failing on the emissions and apprently it's my cat convertor is failing so they are putting a new one of them in for 200. But even then there saying it could be the co2 sensors which are another 200 but got to wait till that cats on to find out.
I'm hoping it's just the cat and I should have to pay around 400 for the work that's been done. Tbh I love the car to much to get rid of it haha
If it has a cracked "air pipe" then it will be running rich and will fail the emissions. Get them to sort that first, take it for a run and get it nice and hot then try again!!
It has a pre and post lambda, you can read them on a basic diagnostic machine too see if its the cat
If it's the lambda a warning light comes in.
Go there and ask for your virginity back.
£200 for O2 sensors? Are they made with Gold connections? You can pick them up for like £30 and they take about 60seconds to fit if you have the luxury of a ramp.
Sounds to me like they haven't got the tools to diagnose the issue properly and they are just suggesting you replace expensive sounding parts to take you for a ride.
Gonna go in there today and ask them about all what you guys have said new it sounded like it was problem after problem :/ thanks guys
If I was you I'd ask them about it and see if they don't give you a straight answer or act shifty.
If you take it to another garage don't tell them the problems you've been told because they may have 'cured themselves' on the way.
WOW
You must have gone to a very very reputable garage my friend.
There are very simple ways of checking emissions, which it seems they haven't bothered to do any and just asked you to spend money, which I suspect you wont have needed to spend.
I'd get that car out of where ever it is and take it somewhere, where they know what they're doing!
