wiring 9n3 rear lights in my 9n! Help please!
hi guys.
just bought some brand new 9n3 rear lights and have installed them, but not fully. i have changed the wires on the passenger side only and put the pins in the correct numbered slots, there is a guide that someone has wrote up which i followed, and it half works. i double checked that the wires are in the correct place twice. but both lights are not functioning properly. apparently drivers side was a straight up swap and plug in and you only had to change over the wires on passenger...
any advice or other guides or maybe even adapters? would be greatly appreciated!
many thanks :)
  • Views 541
all sorted! can delete!
