Mountney wheel boss
Hey polo people. Managed to bag myself a mountney steering wheel from ebay, complete with boss kit but i'm having issues with the horn. I'm not sure how it's meant to wire up inside the boss. Can anyone shed some light on this please? Either a pic of the inside if you have a mountney wheel and boss or just how the horn is meant to be wired up.
Thanks for stopping by and for any advice you can give. Take it easy.
  • Replies 8
  • Views 931
Put a picture up mate, you may have to connect the earth to the boss, I usually use a ring connected and nut of the back of one of the 6 bolts.
Max
This is what i gots. Sorry about delay in reply. I do have a different boss on the way though. post-914724-0-76258200-1407270225_thumb.
One terminal on the horn push should be soldered to the live ring, at the bottom of the hole at 11o'clock in the picture.
The next should be earthed through the boss it's self or the centre of the steering column.
Does it matter which way round they are connected and is the second terminal the little metal bit on the side of the horn button?
I'd connect the terminal in the middle to the live. But essentially it doesn't mater, it's only a switch.
Looking at the horn push again, it looks like it is designed to earth itself when pushed into the boss, I've never seen one like that before, neet!
Edited by MaxVW
I'll have a crack at hooking it up like you said. I just pulled an old wire off and connected those two terminals up to see if the horn would work but it didn't. Come to think of it, i don't think i had the horn button seated in the boss/wheel. Think i just had it in my hand. I'll get back to you on this.
Have you taken the boss apart to solder a new wire to the live ring? It is quite difficult as they don't really take to solder all that well.
Don't forget you'll need the ignition on too.
I haven't soldered anything to it yet. Still need to get wire for it. Also had a new boss turn up cuz the one in the pic is quite short. I keep knocking the wipers on with my knuckles. That one wasn't big enough for the steering wheel.
I honestly don't remember if i had the ignition on or not. I'll pick up some wire and have another go. Cheers dude.
