mk2 1.4 8v conversion, help needed!
Right, so I'm mid way through my Mk2 breadys engine conversion, it is my first engine conversion so its took some figuring out so far, but I'm nearly ready for engine in except for a couple of little bumps in the road.
So to start off with I've got APQ 1.4 8v apq engine and DOW 5 speed box to go with it, and I'm swapping it for my old 1litre 4speed, so far everything fits or transfers across seen as the engines are nearly identical, I'm ditching the injection system and running it with the original 1 litre head and a 1300 golf carb, everything fits nicely and that bits all sorted, the problems are, 1. Main coolant pipe from the water pump and 2. Top gearbox mount and driveshafts
1. The original coolant pipe doesn't fit, so I have to get the 1.4 pipe, but from looking into it, the old pipe has three ports on it, 2 of which go straight to the carb to control the choke I believe, and the other heads straight to the header tank, whilst the 1.4 pipe only has one port, that goes to the heater system, so how can I get around the pipes to the carb, a friend of mine has suggested that I get the new pipe and run the carb on Manuel choke, but that obviously means doing some modification to the carb, but I dont really know where to start on that haha
2. Top gearbox mount is rather different, the original has 3 studs on top to bolt the mount onto, where as the 6n mount for the gearbox mounts onto the car in a completely different place, and also, will the drive shafts be long enough and actually fit, I'm Sure someone who's done a 5 speed conversion can help with this.
any help given will be much appreciated
  • 3 years later...
  • Views 2.5k
You should really of gone for the mk2f 1.3 which drops right in and all you need is the 5 speed arb and box mount
1 ltr head wont do you any favours on a 1400
How did i end up replying to a 4 year old thread?
