Mk2/mk2f bits
Reduced prices a bit for what I have left, need rid.
5 Speed ARB - £17 posted
Facelift Saloon rear bumper - £45 posted
Facelift front bumper, all top clips are broken but it still holds on the two 10mm bolts. - £5 collected or £5 + packing and arrange your own courier
1.3 2G Cam - £13 posted
1.3 2G inlet manifold and rubber flange - £15 posted
1.3 2G starter motor - £23 posted
1.3 2G water rail - £12 posted
1.3 2G fuel pump - £8 posted
1.3 2G Cylinder head complete with tappets - £25 posted
Standard rocker cover - £11 posted
Late mk2 gti steering wheel large spline - £17 posted
Mk2 golf rear bench - £8 collected
Dash complete with glovebox and nearside parcel tray - £20 posted
Saloon rear lights - £25 posted
40mm front lowering springs - £15 posted
Facelift fuel pump bracket, fuel pump, accumulator and filter - £20 posted
Standard facelift fuel lines, return and feed - £10 posted
Carbon canister - £10 posted
Saloon "Polo CL" badge, mint - £8 posted
Standard rear springs - £15 posted
Grey saloon rear parcel shelf - £15 posted
Grey/white sunvisors - £10 posted
Facelift wiper stalk - £7 posted
mk2/mk3 pedal box - £18 posted
Facelift grill with black badge - £12 posted
Steering column with ignition barrel and matching key - £20 posted
Plastic scuttle tray, two small cracks but better than a lot of them - £12 posted
2F ignition coil - £10 posted
Steering column plastic shroud both halves - £12 posted
Wiper motor and associated linkage - £18 posted
Wiper arms pair - £10 posted
2F Coolant expansion tank - £10 posted
Located perthshire, Scotland, pics of anything on request.
Edited by derskine
  • Views 367
very intrested on the gearbox if still avalable ?
Gearbox?
Facelift fuel pump bracket , fuel pump , accumulator , and filter . posted please pm me your pay pal ?
  • 3 months later...
Is the dashboard and glovebox still available? If so could you send me a picture? :)
