Boot build
Morninggggg guys!
Basically I'm looking at taking the back seats of my 6n2 out and making it all one level with a show cage sitting in too!
I know a few people have recently done it but what sort of wood would people recommend using which is easy to work with and reliable/ light at the same time?
Thanks in advance
  • Views 985
I would have thought that 12 mm marine ply (or at least, exterior ply) would be a good choice - much lighter than MDF and reasonably easy to work.
Suggest that you make a hardboard template first of all, take your time measuring, marking and cutting it, then you can simply scribe round the template onto the plywood.
Select the 'good' side of the plywood for the top surface and make sure that your template is the right way up before you scribe onto the plywood, or you will finish up with the 'bad' side of the plywood having to be used for the top!
The finish is your choice, but it could be stained and finished with several coats of polyurethane varnish.
Regards
I heard a story/rumor of somebody getting rear ended and his wooden floor smashed his back in.... It's very possible and unfortunate.
Maybe look at a polystyrene sort of material as a alternative? Would also save on weight.
I've a wooden floor, but only the boot.
Use MDF its no heavier and easier to work with.
