Removing rear badges MK2F Breadvan?
Hi how do I remove my rear VW and Polo badge for painting? I've removed the rear trim panel and can see the pins on the inside is there a damage free technique to this thanks.
  • Views 1.3k
i bought a trim removal tool kit from eBay better than a screw driver and well worth the money . I think they are for internal trims but the forked one did the trick admirably
First Welcome to the Forum.
You might find some gentle heat from a hot air gun/hairdryer will soften any adhesive behind the badges, but if your using a hotair gun make sure its on it's lowest temp setting or you'll damage the surrounding paint
So you don't push the badges out from the pins on the inside?
You either push on the pins if you can get access to them or carefully with a thin flat blade screwdriver lever under the edges of the badge but some have an adhesive on the back of the badges so the heat helps soften any glue, for which ever method you try
I've always used a credit card and just lever them out of the boot.
