front poly bushes for polo classic / golf 2/3
hi all
i have a set of front lower atm bushes originally bought in error for my 6n. the rear bushes will deffinatly fit a 6n/2 but the front ones are too big for the 6n/2.
the rear ones are used (~200 motorway miles) but i wouldn't recommend using just the rear ones without poly fronts and it makes for a very harsh ride and mine tram lined badly, thats why there up for sale.
these are intended for m3 golfs (both 8v and 16v apparently) so vento, jetta and other variants will also fit, as well as above the polo classic etc
dimensions as follow so check yours :)
rear:
outer diameter - 60nn
diameter of bolt hole - 17mm
height - 41mm
front:
outer diameter - 31mm
diameter of bolt hole - 12mm
length metal sleeve - 54mm
inner length (lip to lip) 40mm
price wise in after what i paid for them, so £25 plus postage for the lot.
i can split front and back if both will sell, so lets say £15 each posted
collection is welcome, i am located in ludd in kent TN29 postcode.
thanks for looking
  • Views 290
  • 6kChristoph
    6kChristoph
    So there used and you want what you paid for them?? What dream land are you in ha. Drop the price and i might be interested
So there used and you want what you paid for them?? What dream land are you in ha. Drop the price and i might be interested ;)
Bit of a noob but are one of these where my arb would go into? Using maxrpm blocks on the front for mani clearance
Lol, sotty guys I forgot about checking this.
I wrote that a little wrong, I would like what I paid for them ideally, but I will take as above. I paid 37.50 delivered for them and only the rear ones are used, and very litle use at that.
Make me an offer if the price isnt right for you.
Veedub94, not a noob question at all. These arent for the arb they are for the lower arms, so one at the front and one at the reat on each side. Worth mentioning these are for the bigger golf type subframe / lower arms. So not suitable for the mk2 etc.
