Gunmetal Grey 6n2
Thought I'd put a bit of a build thread on my 1.4 mpi 6n2.
Pretty standard GTi wannabe but had a few bits of bodywork and a fresh paintjob, and obviously some new wheels and a nice drop.
So I started with a mercato blue completely standard except some basic team dynamics style alloys from previous owner.
Started when I had a knock on my way down to Bristol, smashed off my wing mirror so decided to buy some BMW M3 look-alike ones which I'd always liked.
Decided to lower as they sit so high as standard, but didn't have the money to buy coilovers so got some 40mm springs. (Never put them on the car though).
And hated the way the car looked from behind so I had a lot of work to do.
I got a job and some money then started the mods. In chronological order the car had:
Wheels painted black..
Then white.
GTi Interior (with door cards).
Got all my OEM GTi bits (fogs, splitter, honeycomb grills, etc.)
And some aftermarket FK Angel Eyes, only because they were the same price as 2nd hand GTi headlights but had the plus side of being brand new.
Bought 2nd hand JOM coilovers (which was probably a mistake), eventually cleaned them up, then lowered about 90mm at the rear and 100mm at the front.
New panels off a guy scrapping an identical 6n2, so started on the bodywork.
Picked up a GTi tailgate for £50 as well.
So there was a lot of bodywork which I didn't photograph but it spanned around 2 months. It included:
-Removing bump strips from front bumper, rear bumper, doors and rear quarters.
-Smoothing boot handle recess, badge recess and de wipering tailgate. (then adding a boot popper to allow opening).
-Smoothing indicator recesses in wings.
My technique was to weld (plastic weld on bumpers and tig weld on the other steel parts) plates or strips over the hole then only use filler to fill the gaps, then smooth up to 800 grit paper before prepping to paint.
Then I picked up my paint for £140, spray gun for £25 and borrowed a compressor from my uncle. Bought a 9mx3m marquee off eBay which was surprisingly good and my paint shop was set up.
Sprayed all the panels separately, then sent the car in (with all major panels off) to get its paint on. If anyone's interested it's Nissan Metallic Gunmetal, code #KAD. It's what they use on the GTRs but obviously my Polo pulls it off a tad better!
If anyone is wondering about painting their own car, I am by no means an expert, but I am a complete amateur who has given it a go, so here's some advice;
1. Prep work is absolutely everything, tiny imperfections show up 10 fold in final product.
2. Your most important tool is your compressor, a £20 spray gun is good enough for a one off project, but for a whole car, a big compressor, or 2 small ones linked together, is vital, or else you will not be able to evenly cover panels, and like mine your roof will be very difficult to paint, my bonnet is also not bad but far from perfect.
3. Don't let anyone tell you that you need a pro to do it. You CAN do it yourself, but be aware it takes a LOT of free time for the prep work (especially if you want to do bodywork) and you won't get a professional "show car" finish on your first go, but it can still look pretty good.
4. You WILL save loads of money, my cheapest quote for all bodywork and painting was £4200 +VAT. Doing it myself cost me about £500 all in and 2 months of working on it a bit every day.
5. Don't even think about using a rattle can, spray guns are actually cheaper if you're doing a whole car and the finish is much better.
6. If it's an older car (10+ years) just do it, even an amateur finish is better than the paint you'll have on an old car.
7. If you want to build a car to win awards at shows but are tight for cash, spend all your money on the paint job at a shop and do your own bodywork, most bits of bodywork are far easier than a high quality paint job.
Also painted splitter and wing mirrors metallic black for contrast, and the front fogs were tinted retro yellow from before, which works well on the grey.
Reassembled the car, put all the wiring back together and cleaned up all the overspray.
Then the drive to Milton Keynes, (from Kent) to pick up the new wheels, was on. (What a horrible journey).
Went for some 16" 8j all round 3SDMs from their 0.05 collection. Really nice wheels and well suited to the car I think, obviously they are fairly subjective, but wanted something polished with some offset (they're ET20) and just think the car is too modern for most upmarket BBS and not japanese enough for Rota Grids or similar. (I know that last sentence will have really annoyed some people so sorry, I know how subjective wheels are!)
Running 195/45/16s on the rear and Toyo Proxy 195/40/16s on the front. With the coilovers and low pros the ride is a little stiff but not uncomfortable, just permanently on pothole avoidance. In case anyone is concerned, these wheels never rub, and the car is pretty low, more than enough room on a 6n2 for 8js with a little offset.
Anyway, this is how it sits at the moment:
My favourite pic:
And in terms of other changes not seen on in these pictures:
- Aftermarket Headunit with iPod connectivity in top din, then just a tray for phone etc. in the bottom din).
- Custom built exhaust for a nice deep note and to push my bhp from 64 to 70 (which I know sounds laughable but it makes a big difference all through the rev ranges and I can only just about afford insurance on this little Polo so really can't start thinking of anything bigger yet).
- 4 JML Mid range speakers, 2 upgraded tweeters and a hilariously over sized 12" sub in the boot for irritating the residents of the little village I live in.
- Wired in a start button so I could pretend I had a Golf.
- Wired in some remote central locking, which also has the advantage of opening my boot from a keyfob.
- Solenoid to boot release running off a dashboard switch and, as mentioned, the keyfob.
- Slight Negative camber on the rears from some eibach camber shims.
Changes planned for the next month before I go off to Uni:
- Very slightly lower at the front, maybe just the last possible 2/3mm.
- Roof painted metallic black (by a paint shop) as I'm happy with all my painting except the roof.
- Slight wet sand, buff and polish to really make my paint look as good as possible.
- Going to try to attempt a service by myself, would greatly appreciate any input from someone who has done this.
- Order and mount sticky number plate for front bumper.
- A 3sdm windscreen sticker to represent the brand.
- Sort out my central locking which is playing up since I changed the doors.
Thanks for reading guys, any comments/questions welcome, hope I can help people out as this forum helped me out a lot during my build.
Edited by BillyJS
  • Views 4.4k
Looks fresh mate, used to love these wheels but they are rinsed, still nice style and colour though could say the same about quite a few others lol.. like the grey aswell but not keen on the mirrors and I'd put a small rear vw badge but that's down to personal opinion, good job though mate from what she was :)
Fair play for doing all that yourself, no small task. I've painted wheels, door and bumper mouldings but never a whole car
Only thing I don't agree with is the mirrors but it's down to personal taste
Update guys, few little jobs finished off and the car is looking pretty much how I want it now :D
Raised a couple mm at the rear.
Lowered a couple mm at the front.
Proper black roof, done by professionals.
Final wetsand and polish, the paint is now as good as it'll get!
Oh and decided to cable tie front plate on, keep the bumper looking clean :smile:
Off to uni now, so that's how she'll sit for a while.
Long term plan is to maybe get a bit of fancier interior technology (iPad headunit and parcel shelf subs I reckon).
And maybe smooth the badge out of the front grille, if I can find a debadged honeycomb grill for her.
Thanks for looking!
