DerbyII door lock jammed
:sorry:
Driver side door lock is jammed. I dissasembled the inner upholstery and was trying to open the lock by pressing lock levers, but no luck. Is there any way to open it?
Passanger side lock for investigation purposes:
  • Views 750
If the rod in the lower left hand side of the top picture is connected to the internal door handle, I would have thought that if you pull on that, you should then be able to push the door open.
Regards
I have found a workaround of this. Had to drill tle screws from inside. I used my cellphone camera as a lighter (the camera was turned on for video). So, here how it was:
http://youtu.be/yWujlMDoxHg
And this is what happened to the screw:
Edited by Hiisi
