Cleaning engine bay / exhaust pipe etc - 6N needs a little spruce up!
Hi guys, my 6N is in decent shape after a few repairs but a couple of things are bothering me like the state of the engine and the exhaust pipe, any recommendations as to a product that could spruce these up a bit and make them not look quite so dank and knackered?
Less irritating but irritating still are these two small issues. The seal on the roof is coming away a little, am I ok to clean out the water and muck underneath and glue this back down? Also can anything other than a refurb on this alloy make it look less crappy and maybe get out a few of the marks on it or do I need to go the full refurb route?
Thanks guys :)
Edited by michaeldc
  • Views 1.3k
No a lot you can do with the tailpipe other than fit a new one.
The engine bay, a good steam clean, being careful to wrap up and electrics. Or try some Gunk.
2.
That's exactly what I'd do, clean under neither and glue it down.
3. Without flatig it back and repainting it I doubt there's much you can do.
Max
Thanks Max, picking up the car from the garage tonight after having new brake discs/pads, exhaust clamp and spark plugs fitted so will ask for a quote for fitting a new tail pipe as it does look really poor. I'm back there in a couple of months for my MOT so might get it done then if it's cheap enough.
I'll probably go the gunk route as it's on the metal finished parts that really need a going over, a steam clean might be overkill on this one and I wouldn't trust myself to miss some electricals, if I can get the metal bits on the engine looking good and then wipe down the plastic I think it'll look tons better. I care about all aspects of the car and want them to look clean and tidy, I guess it won't harm me if the tester notices a nice clean car that's been looked after!
I'll pick up some superglue tonight and sort the seal there and I'll leave the alloy alone until such a time comes when I can't stand to look at it, it's not that important... I guess!
Superglue is not the best choice for this job (or for any job come to that!) You would probably be better with a latex based glue (Bostic etc.)
You need to be sure that you have got ALL of the dirt out and that both surfaces are clean and dry - it would pay to wipe over with some petrol, carb cleaner or brake cleaner on a cloth, then allow that to thoroughly dry.
Coat BOTH surfaces with the glue (evenly, but not too thick) and allow to dry DON'T touch it after it has dried - It will take about ten minutes to dry on a warm day.
When the glue is dry, bring both surfaces together, starting at the 'fixed' end and press down hard, again working from the 'fixed' to 'free' end.
If you can put a heavy book or similar on it overnight, so much the better.
Regards
Thanks caretaker, the car lives on a busy road so books likely not an option sadly but I'll take the rest of that on board and look for some Bostic.
I spoke to my garage today who said the tail pipe looked crappy but was sturdy enough. I asked if I could buy a short chrome tail pipe and they said they could fit it very cheaply by cutting the rusty part and simply affixing the new smaller, straight tail pipe - apparently it's a 10/15 minute job. Can anyone advise if the link below is one that will fit? It has a 60mm opening that affixes to the remainder of the current tail pipe but I am unsure of the circumference of the original tail pipe. This new one is small and unobtrusive and will surely look a hundred times better than the rusted monstrosity currently sticking out the back the car!
http://www.ebay.co.uk/itm/CHROME-EXHAUST-TAILPIPE-TIP-TRIM-END-MUFFLER-FINISHER-VOLKSWAGEN-VW-POLO-GTI-TDI-/200812148496?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2ec1563710#vi-ilComp
The standard pipe is around 40~45mm so that chrome end should clamp down onto it
