Interior door handle screw....
Another daft one from me... one of the screws under the cover of the door shut is missing on my car making the interior handle loose and susceptible to being damaged the more I use it. I need to find the right size screw for this slot to ensure a) it's secure and b) that it's not so long that it would damage the window when wound down.
I checked all the other screw in both doors but they only unscrew to a point and I can't get them out to check the size which is very annoying!
I know this is daft but I wondered if there was a recommended part or size screw before I go out and buy a bunch to check them randomly.
Not my photo but this is the section I am referring to, there are two screw holes like in the top right corner of the picture.
Edited by michaeldc
  • Views 839
#7 M6 x 20 panel screw N 10243401
post-36925-0-18920900-1408537959_thumb.p
Thanks Nige, I was sure that post would get a scathing reply instead of a helpful one!
I'm presuming I can use any M6 x 20mm screw in there so I'll pop to my local hardware shop later!
Yep, any M6 screw will do !
Got one and fitted it and now my handle is solid!
Thanks Nige :D
