6n2 Window crank bolt
Hi all,
New to this so sorry if this is already a topic somewhere else on the site but i couldn't seem to find it!
I have lost the screw that holds the window crank to door :sorry:
Does anyone know the size or where i could buy a replacement from?
Thanks in advance!!
  • Views 894
First welcome to the forum.
The winder crank handle is not held onto the splines by a bolt/screw ! there is a horseshoe clip that secures the crank to the winder shaft
Thankyou!
I had heard this originally but when removing mine i found that it was held on with a screw that threads into the end of the spline rather than the horse shoe type clip.
I also made the mistake of buying the wrong crank due to this mistake too!
I will post a picture up for you when i am back from work.
