leaking footwell
Every time it rains my passenger's footwell fills up with water. I've been trying to find where it's coming through for nearly a year now and wondered if anyone could help! It's not coming through the scuttle panel by the wipers, not the rear light clusters and I don't have a sunroof.
The water seems to be dripping from the inner wheel arch, but only when it rains. I have thought about replacing the door seals but they appear in good condition. Is it worth the £50 punt? Any help /similar problems would be appreciated.
I can't remember off the top of my head exactly what it is but if you use the search function you'll find a ton of posts similar to this. Good Luck :)
I'm not exactly the best person to give advice but if it's were me I'd get a friend to use a hose on the area and sit inside trying to see where the leak is. Then I'd plug the hole.
Obviously I'd take care not to hose water where it shouldn't be hosed such as close to electricals for instance.
Edited by michaeldc
Thanks alot guys. I've been searching for similar posts but none are quite the same as mine. If I stick my head up under the glove box it does seem to be coming from around the wheel arch which is a good foot away from the door. I think I've ruled out door seal now.
Does anybody know if there's a way of telling if my heater matrix is leaking? My pollen filter is dry?
From memory one of the two things was either heater matrix but as you said pollen filter was dry so I think that's okay the other option was that the drain holes along that area of car had been blocked. No idea where they are but normally a pulled out cloak hanger can fix that... this is based on my 6N so not sure if it applies with yours.
Is it a 6n2? I fixed one leak that was coming up through the floor a few months ago and yesterday another leak sprung up coming from somewhere under the glove box, sounds pretty similar
Does it have a sunroof? Because a very common fail is a block drainage tube down the a pilar. It gets block and the water finds another way out equating to a nice soggy footwell.
  • 7 months later...
no idea if you still have this problem mate, but i just got my mk2f recently and noticed something similar happen, for me it was just a rust patch under the outside windscreen seal, I'm probably 6 months too late but hey ho
