Two annoyances with outside damage to car
Hi all, I have two minor issues that aren't a huge problem but don't look particularly good. The first is a broken part of the section below the lights and grill. I don't know what this is called so I can't search for this piece specifically, in the past it was glued on but it came unstuck and I can't get it to stay there anyway even using bostik, I'm wondering if there's anything I can do or if I can get a replacement part.
The second is the broken plastic on my drivers side wing mirror. It may just be missing a screw, I'm unsure, but when I pull the mirror in when parked the black plastic comes away like in the photo. From the inside there is only the body work behind it and no screws that could be missing, perhaps the front part comes away to reveal a screw? I'm unsure as I can't see properly.
Michael
  • Views 994
The broken part is the lower part of the radiator grill part no 6N0 853661C GRU (primer) 52€uros in Germany, best have a look in the cars breaking section.
The wing mirror there is a mounting screw at the front end of the base plate that should stop that from pulling out like in your pic
Thanks Nige, checking with car breakers but not holding out much hope.
Re: the wing mirror, I presume the screw should be accessible on the inside somewhere but damned if I can find it, do I have to pull the door panel off on the inside to get to that?
Remove the door panel, then you can remove the black plastic trim #8 in the front corner and under this are the three screws that hold the outer part of the mirror base to the door
post-36925-0-70852800-1409696517_thumb.p
The black plastic trim sits on top of the door panel on mine and came off with little effort, oddly (looking at that diagram) it only exposed 1 of the screws. I removed the door panel and exposed the other two and sure enough a screw was missing (how does that happen!) - I moved the two OEM screws to those bottom two holes and left the top which is easier to access without. Fortunately I found a screw that just about fit in the top one and put it in as a placeholder. The head of the screw isn't quite wide enough for me to be confident but it'll do as a placeholder until I can get one more appropriate. Removing the panel also gave me the chance to replace a small at the foot of the inner door handle - annoyingly the material on the other side of the panel which holds the screw head on the other side was torn, hence why it came apart in the first place. I used a rubber washer to wedge it in place before screwing it in and it seems to have done the job. A couple of mysteries solved but more have appeared as it always the way!
Thanks again for your time Nige :)
Edited by michaeldc
