6n or 6n2
Hi guys. I'm new to the forum but was just after a bit of advice. I'm looking at getting a new car and have narrowed it down to a Corsa B, a 6n or a 6n2. I'm after something reliable, and something cheap to run.
I was only looking at getting a 1.0l, which is what puts me off the 6n's because you can only really get hold of the 1.4's and I assume they're more expensive to run, but correct me if i'm wrong as that will change my decision completely. But on the other hand I don't want PAS which is what puts me off the 6n2's. The Corsa B seems like the best of both worlds but I can't find one atm, and I want something different as i've had one before.
I know i've made it long winded (i apologise) but basically, what would you guys recommend the 6n or 6n2? And how much more heavy on petrol is the 1.4 6n compared to the 1.0?
Sorry it's so long but any help would be great, thanks :)
  • Replies 14
  • Views 1k
First Welcome to the forum.
The 1.4 tends to be slightly better on fuel than the 1.0 as the car weighs the same for both engines, so the 1.0 is working harder to pull the same mass. The 6N's do suffer from rust (sills, rear wheel arches, etc) the 6N2 has a galvanised shell so rusting is less of a problem, if you go for either make sure the gearbox selects all gears ok and makes no noise as they are the weakest point on both models, if you get the right year of the 6N2 the 1.4TDi is only £40? year tax! Not sure why your against PAS?
I've had/got a 6n 1.0, 6n 1.4 and 6n2 1.4. My friend has a 6n2 1.0. They're all roughly the same on fuel. 1.0s are scarier to pull off on a busy island and out of a risky junction. I'd say my 1.0 is slightly worse on fuel because you have to rev it higher in each gear to build up speed at a reasonable pace.
6ns are better than 6n2s. The late 6ns (99 onwards) are also galvanised but it doesn't prevent rust 100% as my 6n2 started to go on the arches. 6ns have a better build quality when I compared both my cars. Everything I took off my 6n2's interior snapped, bent or broke. Where as, had no problems like that in my 6n.
As for insurance 1.0 - 1.4 no difference really if there is it's about £10.
A lot of 6ns have power steering as well (mine doesn't)
As for a corsa B :lol:
Thanks guys that's really helped, i'll start looking into some of the 1.4's then. The fuel thing does make a lot of sense. I don't know why i'm against PAS tbh, I just feel like you don't get as much feel for the road if that makes any sense haha?
I've owned a Corsa B before and it was so easy to work on, and I never had any problems with it. I did fall in love with it tbh, but i've always wanted a VW so I think it's the right time.
Went to look at a 6n2 earlier, first one i've ever looked at, and I was really impressed. Decent bodywork, low miles, started and drove really well. The only couple of things were that I struggled to get it into reverse, and the clutch felt like it pushed down more than it should have. Both of these could have been because i'm not used to it, but i'm really not sure. Are either of these common issues or is it more likely down to my incompetence haha?
There is a known problem with the pedal box on them that affects the clutch pedal, the support for the pedal can crack, you need to get your head under the dash and look for cracks around the pivot shaft area
Ok great. It's from a dealer so I'm going to get him to look over both issues just to see if it is all ok. I hope so because it was a nice little car
Every one always crunches my 6n into reverse but I never do it's like there's a nack to it
If he rings me back in the morning and says it's ok I think i'll go for it. He's asking £999 but i'll try and get him down to £900. I think that's a fairly reasonable price
Looks OK, No mention of a service history? but @ 71K on the speedo it's low miles for the year, see if there is any mention of the cambelt being replaced ( 60K or 5 years)
I did ask, he said it has service history but no receipts which kind of put me off. Asked about cambelt and water pump too but didn't get an answer about either of them
It's not the end of the world if there isn't proof of the cambelt as a kit is around £30~40 and £25~30 for the waterpump and its an easy diy job 1.5hrs So it could give you a point to get the price down a bit :)
Going to have another look at it tomorrow and i'll try and get a bit more out of him. He's fitted a new exhaust and a new radiator that's why he's pretty stubborn on the price but this might give me a bit of leverage now, thanks mate
I've got a 1.4 6n2 as a daily driver. I easily get 40-45mpg with mostly driving on country roads. Its been a fantastic car so far. I've had it for nearly 5 years and put 45k on it and its nearly at 100k. Apart from the headlights starting to mist up, it's still in good shape. I needed a new pedal box a few years ago for reasons similar to what you mentioned and a new vacuum hose for the brake servo. Apart from that, its been very reliable. I'm sure as long as the car has been looked after, you won't go wrong with it :)
