6N door pins replacement
So when I removed the door panel tonight to fix a missing screw, the ring by the door pin went flying off (I hear this is not uncommon) and while looking at the door pin critically for the first time ever I came to the conclusion that they were rubbish. They look tacky I think and it wouldn't be a bad thing or a costly thing to replace them. I found the below thread about such a thing:
http://www.clubpolo.co.uk/forum/index.php?showtopic=103477
But after searching, I can't find these parts anywhere. I also thought it would be better to get smaller ones that would sit flush when locked. Has anyone replaced their door pins for something a little more stylish and discreet as I'm suggesting?
  • Views 892
I looked for ages for the 6n2 ones but gave up. If you find a solution though post the links please :good:
I appear to have found some so I ordered 4 pins and rings (left and right) - if they are what I hope they are, I'll send a set your way vdoubleu - just pm me your address and I'll forward them on, no charge. Fingers crossed he doesn't just send me the crappy standard ones!
I just cut my rod down on my 6n2, filed the threads out of the pin and now it sits completely flush when locked
would be exact same process on 6n to have them flush
Emailed Stevens VW spares and they had some so I bought 4, 2 for me and 2 for vdoubleu who also needed them. I plan to make them flush so will cut the rods, file the thread from the inside of the pin and hopefully it'll be as flush as Matt's - I'm presuming I'll need to glue it in place so it doesn't fly off when it jumps up. Looking forward to adding this in tomorrow!
