Black strips on the roof
I was washing my car to other day and checked under the black rubber strips on the roof and the strip of metal that you push the strips on to, one has broken off from rust :/, just wondering if any one has filled them? If so any pictures? Can't decide if it would look ok or not
Cheers in advance
  • Views 1.5k
It's quite a big gap to just fill, It'd probably end up cracking along the join after a while and looking a bit poo, ideally you;d want to weld the recess and then smooth over will filler and then paint.
If it were me I'd go down the route of getting a set of 6n2 roof rails and if needs be, gluing them in with some tigerseal.
would of used fibre glass, will have a look at the 6n2 roof rails, I don't have access to a welder at the moment unfortunately, are the 6n2 rails a direct fit or will they need modifying?
thanks for the reply buddy,
They're a straight fit dude, no modifications needed.
They're solid plastic too from a 6n2 rather than the rubber ones on a 6n so they look a bit neater and fit more flush.
sweet, another thing on my to buy list lol, so you reckon get them and tigarseal them on?
If the metal channel that they clip onto is broken then tigerseal should do the job.
sweet, cheers buddy :)
