Potential New Polo, Thoughts?
My current 6n is on its way out, rusty sills,oil leak from sump.looking to get a new 6n but was after your views of this based on info I have been given.
6N 1.4CL
65k miles, cambelt changed when current owner got the car at 35k miles. Is this going to be okay or should I be wary? He says he has reciept for it which is good he took it to Poland so my assumption is he got it done before that?
The car has only had 3 owners, 1 of them being him. Never had anything go wrong apparently bar a tailpipe being replaced.
What do you think? Any opinions would really help.
  • Views 655
Anyone? Going to view tomorrow and would appreciate some opioions from people with more experience than me
There's very little sound advice I can offer you personally but I can tell you about my experience of buying a 1999 1.4CL 6N on June 1st this year. It had 92k on the clock and most of the car is sound but like any used car it had it's fair share of problems. It had 2 previous owners and while the first took great care of it, it's obvious the second wasn't quite so bothered and lacked a little pride of ownership. If I were buying now having known then what I do now, I may not have bought it.
It's good that the car has a new(ish) cambelt, Mine was in a bad way and lacked tension when I got it replaced and I feel fortunate it didn't go on me which would've been a complete nightmare. The other thing that I had issues with was a leaking power steering pipe which was far more expensive than I imagined it would be. The things I would look out for when purchasing a used car now would be to physically check the tension on the cambelt and to look for any leaks very closely, I would also check the general condition of the car to see if the current owner has cared for it. Pride of ownership is a big deal to me as I have it and I get things fixed asap instead of letting issues build up. Check the bodywork for rust and/or touch up paint. If there's a lot of rusting going on then maybe the owner isn't too bothered but if there's touch up paint on it, then perhaps the owner cares enough to try and fix up minor marks and dings before they get worse. Is the interior is decent shape and clean or a complete mess? It might not mean much but it would be enough to make me think about it very carefully. Check the wheel arches and the wheels, is there decent tread on them or do they need to be replaced?
At 65k on the clock, that is a low mileage for a 6N so you could certainly be getting a good deal but the truth is, you just never know with a used car what surprises may be waiting for you. When test driving, listen for an oddly noisy engine and driveshaft, do the gears shift easily? Get it up to a high speed and listen for rattles or vibrations, it could be a loose exhaust, a damaged clamp or simply bad balancing on the wheels - it all costs money to sort out so factor it in when considering a price. Check the tracking when driving, does it veer off to the side or is it pretty straight? I'd also check what is coming out of the exhaust when revving the engine, white smoke and dark black filth are not a good sign. Finally, if I was happy with all that I would check as much of the electrics as possible, central locking, all lights, electric windows etc, check it all - it may not all work or need some rewiring but at least you can weigh up the time and effort you will need to put into it and see if you're still happy with the purchase.
You may well know all this but I hope there's something in this diatribe that helps!
Michael
Edited by michaeldc
Yeah this helps a lot, what are the signs of leaky power steering hose? And where shall I look for this? My current 6N is the L version so no experience with the additional features of the CL.
I'm confident of the car and the current owner but will be walking straight away if it's not for me. (As much as I'd like to buy regardless of issues)
Thanks!
Two points on power steering, first of all there will probably be a leak of fluid on the ground just under the front of the car as the power steering pipes run very close to the front bumper, you can even get under the front of the car or inside the bonnet and check the hydraulic (metal looking) pipe for any corrosion or leaks. If there's no fluid in there the power steering pump will attempt to pull fluid and instead just pull air - when you start steering you'll hear a high pitched whirring noise, it'll be very much audible and you'll notice it as it's so different from the regular engine noise - if it does this enough it'll damage the pump and that'll be something else to fix. It's not cheap either.
To be honest, it's not something I imagine will be a problem but from experience, if it is, it's a no no for a buy unless you have plenty of spare cash to splash on it... like I didn't but had to find anyway. Same goes for a loose cambelt, it's not a cheap fix and can be detected before buying.
All this being said... I love my car and I think it's ok now so I'm reasonably happy even if I have paid over the odds for it including repairs (cambelt, power steering pipe, loads of electrical issues plus other minor things).
Take your time over it for sure and check everything you can!
How did it go mate?
