Bonnet Cable has snapped, how do i open the bonnet?
so basically, i want to get under the bonnet but cant, pull the handle and the bonnet doesnt release, i've tried a screwdriver through the front grill, tried through the offside side repeater to get hold of the bonnet cable to pull on, no joy, HELP!!
  • Views 5.6k
Try from underneath the front of the car, there should be a big enough gap to get some tools in there, will still be finnicky though
I had the same issue a while back. If you go in through the grill, i found it easiest with a torch or light, just to get it in the right place to push the catch to one side. It is fiddly and i found a long 'driver with a narrow shaft and small flat head worked best. Too big a head/shaft, and too short a driver didn't work. It is fiddly but when you've done it once, you're pretty much golden.
