Parking sensors... Don't laugh!
Ok so I know this seems daft on a 6N because it's so small but I live on the busiest little road you can imagine so anything to help speed up parking so I don't annoy everyone queueing behind me all the time!
I picked up a set off ebay and have seen installation videos so I'm totally prepared to give the install a shot on my own (got the power drill out and ready to roll!) - I used some masking tape and marked off the positions of the sensors on the top part of the bumper but then had to stop and think a little more. In my head the bumper is hollow with nothing behind it except the chassis of the car so I will need to remove the bumper in order to feed the wires through - is it easy to remove the bumper or a total nightmare? I don't have a lot of tools but I reckon I can get the 4 large screws at the top off easy enough but are there others elsewhere and any special tools required? Also are there any pre-made holes in the chassis to feed the wiring through as looking through the boot to the back, it seems pretty closed off.
Any advice on the removal of the bumper and getting the wires into the area by the passenger side rear lights would be a great help!
  • Replies 12
  • Views 957
  • There are 3/4 screws in each wheel arch that also need to be removed, then the upper plastic bumper cover can be pulled off, there should be a rubber grommet in the rear panel that was for towbar elec
  • Fit them so they're tight to push in to as there isn't much holding them in bar the hole itself, tendency with the generic eBay ones is easy install as most tend to only require a earth and live feed,
There are 3/4 screws in each wheel arch that also need to be removed, then the upper plastic bumper cover can be pulled off, there should be a rubber grommet in the rear panel that was for towbar electrics that will allow your wiring to get into the boot area
Interesting, I can probably drill the holes with the bumper still on, providing it is hollow and there's nothing behind it and then get under the car to feed the wires in without taking of the bumper.
If I do need to take it off, can I access the arch screws without taking the wheel off?
Thank you Nige :)
Edited by michaeldc
There is clearance behind the plastic cover, you have a bumper bar before you'll hit the bodyshell, but with the cover removed you can make the holes in the correct place for maximum clearance, better than drill the holes and find the bumper bar is in the way for the rear of your sensors!!
It is easier to get at the screws in the arch if you remove the wheels
Fit them so they're tight to push in to as there isn't much holding them in bar the hole itself, tendency with the generic eBay ones is easy install as most tend to only require a earth and live feed, I'm sure nige will be able to tell you the exact pin to probe into for the reverse feed and from what I recall on my old 6n there is a earth point by the rear lights held in with a 10mm bolt (nige correct me if I'm wrong) you can either get a little ring connector and bolt it on with the rest of them or just lossen the bolt a bit strip the wire back a fair bit then just twist it around the bolt threads and tighten it back in.
Also most have a self fault finding so if you have a dodgey sensei it will beep in a certain way to tell you it's a fault with sensor ABCD/1234 depending on your kit. So try when fitting to go from left to right with the sensors in the bumper in that sequence so 1234 or whatever then plug the right sensor to the right port on the box and you'll know exactly what sensor is faulty should it ever happen
Having studied a few pictures and measuring up the size of the bumper I was pretty confident i could drill without removing the top bumper and sure enough the holes are in there now and there's plenty of clearance for the sensors so that's one part down, the reason I did this is because I have no work bench to drill on so I needed the screws in to steady the bumper as I drilled.
The problem I'm having is getting the bumper off but I may be able to avoid that as there are small gaps in the bottom, the main issue thouygh is that I will have to get the bottom bumper off so I can feed the wires to the hole in the boot floor. Is it any easier to get the bottom bumper off or does that also involve screws inside the wheels arches?
Michael
You have to remove the upper plastic cover to remove the lower metal part, and that will involve removing the screws in the wheel arches
Ok so, holes drilled, sensors in and currently fed through the same gromit as the license plate lights which was handy, though I'll need to do some jiggary pokery to get them in the rubber and then fit the rubber back in... I got the screws out of the arches without any real problems and and the four along the top of the bumper easily too. There must have been some others elsewhere but for the life of my I couldn't find them, fortunately the bumper does pull away enough to get inside and at the gromit.
Only two questions remain and these are probabley for any polo owners who have done this or the knowledgable Nige! Could anyone confirm the that there is an appropriate power wire going to the reverse light on the 6N for me to splice the red wire into and is there a suitable grounded bolt nearby that I can attach the black wire to?
Thanks again guys, getting there slowly!
Michael
On the left rear light connector splice into the Brown wire (pin 1) for the ground and the power from the Black/Blue wire on pin 2
you could always just leave the bumper bar off?
Hi Nige, can I just confirm this as I spliced in the below but got nothing.
Black/Red wire --- Brown (pin 1)
Red wire --- Black/Blue (pin 2)
Is that definitely right? I might need to re-splice, maybe I didn't do a good enough job on it but I thought it was fine.
Michael
The switched power for the reverse light is definitely the Black/Red wire it should be on pin 2 but I'm not sure if these diagrams are for our RHD so it might be on pin 4 & the Ground is definitely the Brown wire again there is some confusion on the pins but there is only one brown wire on each light unit and from memory there is a grounding point (10mm nut) by the rear light cluster
I went out, re-wired it and hey presto, now it works, guess I was just careless first time round - the good news is, it all works now so thanks again Nige, top man as usual.
For anyone reading this after the fact, Nige meant to repeat Black/Blue as the switched power on pin 2 not Black/Red - he was exactly right first time round. I should never question the man!
