Breaking J696GNH polo T40 195ish bhp with all the trimmings
Ok my car has been for sale long enough now with no interest so it has now been broken into the following list of bits. Photos are available in the following album i could post individual pics but the thread will get silly long quickly any more photos please just ask.
Location Yeovil Somerset, will post smaller items will get price when people ask will be using royal fail for most items DHL for larger stuff. Larger items such as seats, engines etc are collection only unless you arrange courier for specific time/date I am working alot of hours right now but can be flexible if specific times and dates are given.
Pics <iframe width="480" height="360" src="http://s673.photobucket.com/user/antywill666/embed/slideshow/"></iframe>
There is also a youtube vid of the car running and everything you see is for sale! the link is here
https://www.facebook.com/l.php?u=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DPC3Z8pxkWIg%26feature%3Dyoutu.be&h=UAQGNUHbQ
https://www.facebook.com/l.php?u=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DmP1jDrjnZm4%26feature%3Dyoutu.be&h=UAQGNUHbQ
All parts have been on the car for roughly 5k just run in everything is in good working order as I drove it before breaking it yesterday (15/09/14) and it went like a dream with everything functioning correctly.
Any questions please pm me
1341cc engine with accralite pistons rebuilt 4k ago. Includes short motor and polished and ported head with 268/268 “turbo” cam cat cams vernier pulley new water and oil pumps all new gaskets etc etc.. will consider splitting cam and vernier if other parts have buyers £1100 inc cam and vernier pulley
K03 turbocharger came from a passat with 60k on it I have since added 4k to that. Good condition no play in the shaft holds boost fine £150
Forge actuator with spring kit to manual adjust boost painted white comes with both standard and custom mounting plate so that you can rotate the compressor housing further for extra clearance £80
Rothe cast iron manifold to suit PY engine. As we all know these are decent quality durable plug and play turbo manifolds for the g40. £350
Turbocharger water lines made from solid copper/nickel alloy for corrosion resistance. These where made by me as they look neat and tidy with swaged ends, they will come with all the adaptors and t pieces which were also custom made by me machined from round alloy stock and tig welded where required. Compression fittings may require new olives when being refitted. One silicone join has been made in each pipe to allow for engine movement silicone may need replacing. £100
Turbo oil feed lines, these are -8 and -10 in size if I remember correctly( both are sufficient for turbo feed) ptfe pipe to cope with the heat and not degrade like rubber with a stainless over braid. Both come with the correct fittings to fit a k03 however I only have one set of fittings that fit into the head. £40 each
Turbo oil drain for a k03, this consists of a solid flange welded to a solid pipe wich has been bent to fit using the correct pipe bender, the hose tail itself is roughly 10” long with hydraulic hose that has the correct 90 degree swivel fitting swaged on the other end cant remember the exact size but its female jic will find out size.i did it like this in two parts so that if the rubber hose part is damaged it can be easily replaced with one jubilee clip and the swivel fitting rather than having to remove the whole assembly. £35
GT inlet manifold port matched to the head. It has been drilled in the lower half of the plenum to provide a vac source with a small 1/8th BSP hosetail fitted, this is what i used to provide a vac source to my boost gauge, BOV and other accessories. £50
51mm throttle body, this has been modified for the 6psi boost switch. It has had the what switch removed, an external what switch has been fitted this was used with the nitrous system i fitted to the car although it can be removed. The boost switch has been neatly installed in the side with a hosetail for easy connection of silicone pipe.Comes with the top elbow which has had the linkage and butterfly removed for boost return so that I could fit a BOV in its place. Also has a tapping and a blanking bung in the back for nitrous :) £150
45 degree silicone elbow in 25mm (I think) with custom made aluminium adaptor to reduce down to 25mm from the 45mm elbow outlet size. This comes with a bailey BOV painted white god condition working fine £45
Aluminium airbox/air filter holder to fit in fog light recess. This requires the removal of any wheel arch liner. It consists of an aluminium box made from 2.5mm sheet metal and tig welded with an open front. The box was mainly to protect the filter from and crap coming from the wheel and wheel arch area whilst exposing the filter to the fresh air from the fog light hole. Comes with a generic cone shaped filter and convoluted hose. Silicone reducer and all nipples to fit direct onto the inlet for a k03. The custom silicone joiner was pretty pricey as it goes from 3ish” down to 45-50mm hence the higher than average price on this. £100
Intercooler actually bought this from Yoof its from a diesel engine 4wd but it happens to fit rather nicely in the front of a polo I know a few other guys run these. This one is in decent condition painted black and can come with the radiator bar below it which has been chopped about a fair amount and strengthened underneath with gussets. The bar will support the aluminium radiator and the intercooler (mounted on the correct rubbers) and is a simple bolt in fit to your polo has been powder coated black to stop corrosion. £65 intercooler £35 radiator bar
Aluminium radiator. This one took a lot of time and messing about to get it to work correctly. Bought as a pattern aluminium one for a mk2 golf it’s bigger than standard. The end tank has been welded because it leaked from new, a piece of aluminium has been welded in to stop water flowing in through the top of the end tank and straight out the bottom of the end tank without actually passing through the rad. This took a lot of time and messing about. Some of the mounts have also been moved. Moral of the story buy one that fits in the first place!!! However this one now works and fits fine will fit very nicely with the radiator bar and the intercooler may need to drill two holes in the slam panel for mounting up top can’t remember of the top of my head now. £200 For the record the Radtec ones currently retail for £244 plus vat! http://radtec.co.uk/products/330/Universal-Radiator-Polo-.htm
Pacet pro fan 11” this is a really good quality fan currently fitted on nice little stainless steel mounts that fit my aluminium radiator, mounts don’t flex as i triangulated them and they now look like little toblerones with tabs on! Moves a lot of air i can find the specs if required but it drops the temp in my car almost instantly in traffic on a hot day when switched on. I bought this new from deamon tweeks it was around £80 plus vat plus postage fits behind the radiator and I&#39;m pretty sure is non reversable. Comes with and amp sure seal plug attached and extended wiring £65 fan £10 mounts These currently cost £105 delivered from deamon-tweeks
310cc injectors these came from a Volvo i think orange in colour bosch in make had them cleaned and tested and the current map in the ecu matches these. PART NUMBER: 0280150785 SPEC: 315 cc/min , 14.5 ohms
£100
Polo g40 digipants ecu £100
Engine loom re wrapped recently and all joins re soldered covered in heat shrink then self amalgamating tape (done by an ocd electrician!) £100
K03 down pipe not sure who made this one good quality though stainless steel with slide/push fitting has two lamda bosses welded in it currently wrapped in painted heat wrap in black. Which has fully cured and doesn’t smoke at all!! £150
Short flex wich fits between the downpipe and the rest of the system flexi is the shortest they do cant remember exact measurements but will get them £20
Full PPP exhaust system twin silenced good condition few very minor scuffs on £400
Custom made exhaust hanger mount slots over your old manky one and is geld in place via two bolts and negates the need for welding a new one in! £35
fuel tank that has been stripped and coated in por-15 £50
Fuel pumps both lift and an uprated inline one good for 250 bhp working on the manufacturers flow rating at max pressure £40 for the inline £90 For the lift as it was genuine includes the guage sender and cost me over £200 new from vag! Don’t think you can actually get these any more for from VAG got receipts to prove!
Fuel Cradle and all fittings etc can be thrown in for that has been shot blasted and por-15'd £20
Completley refurbed rear drums with all new shoes drums springs shot blasted painted new stainless nipples etc etcc £35per side
Shot blasted and painted (por-15) rear axle £35
Rear brake compensator £20
All new kunifer corrosion resistant hardlines from the compensator back £75
Braided flexis for the rear £5 eachUniversal poly exhaust hangers thing i have two of them came from Daemon tweeks fit on the car perfectly and don’t fall apart cost £20 new £5
Custom made catch tank and bracket needs a new filter but has a 25mm inlet 25mm filter fitting and drain tap with sight gauge on the side, there is a baffle plate inside to stop oil coming out the filter. £40
Poly engine mounts x3 these really help to reduce engine movement slight increasing in vibration at idle speed (made my car sound better not sure if that’s good for the chassis but made me smile) £85
Stage 3 subframe, this comes with on car adjustable tension struts in good condition all boots intact and all rose joints still tight and fully greased, any scrapes where touched up with por-15 to prevent corrosion £450
Camber adjustable tcas brand new with all bolts etc £250
Custom designed gaz coilovers made 9 different body length, different piston length, different steering arm height, different spring rate) for more travel at just below standard height do not buy these if you want your car low it will not ride correctly the steering arms will be at the wrong angle and there will be little to no bump travel you have been warned!! They come with various different springs best setup i had so far was the current 350lb springs. In my opinion to make this setup perfect and maybe go a bit lower some helper springs would be a good idea and some custom back struts with a longer body to increase the ride height at the back so without adding preload to the spring to obtain the correct amount of ride height at the back. But that is me being a perfectionist. These have been on the car for roughly 6 months and stripped bare and painted in por-15 which is a way better corrosion protection than the crappy black zinc coating they come with from the factory in my opinion!! Come with custom made shock covers too keep them clean and the threads functioning correctly. All new quality skf bearings struts bolts and bushes and top mounts  £650
Gearbox currently wont select 2nd gear all the rest work fine i will split it so any one want any spares as i know these chocolate boxeses are not made any more and break for a past time. £50 for spares also have a spare standard diff to fit in the box £10 or free for asking price of box!
Quaife diff with a pair of genuine decent quality diff bearings and the correct shims for the preload in the box they are currently fitted. This is the one for an ATV think its QDf20 or something along those lines £500 no offers
256mm brake setup with all bolts and flexis. Fitted with standard brembo discs and ferrodo ds2500 with plenty of meat on the pads alone i remember being really expensive and the bolt on brake upgrades are like hens teeth these days so £300
22mm master cylinder ( cant remember exact size but the bigger one required for the larger brakes) again pretty new bought it new from gsf when i rebuilt the car £35
Head lights i have two genuine OEM sets in good condition £40 a pair
Clear indicator lenses one pair of £25
Clear side repeater lenses £5
G40 rear lenses with the smoked section £45
Pair of corbeau boss seats in excellent condition , these are sports recliners so you can tilt slide and roll them fowards to let people in the back would really prefer to sell them with the subframes which are bastardised corrado ones which will slot straight in your polo £300 With the frames £250 without
A pair or schroth retractor 3 point harnesses these will fit your current mounting points and come with retractor reels that work on intertia and a tilit switch they can also be locked manually for track days etc but mean you can still lean foward at a junction ! £250 They are black with black writing on
Stack 52mm all analogue oil pressure guage £35
Stack 52mm mechantical boost guage £25
Stack 52 mm Wideband lamda with 02 sensor and all wiring £200
oil (ptfe) braided house to fit with t pieces £40
Alpine x305s full control ipod head unit lovely head unit currently in a centerconsole mounted cage it was going to be used as a mould for a fibreglass one so its not pretty but it has been covered in faux leather and can be chucked in if the full asking price is given for the head unit £100
Full flat floor install with wooden supports and thing marine ply topping including spare wheel well amp mounting, can be installed in your car for labour cost and adequate space provided for me to fit it. Really tidys the back of the car up and provides ample space in the back for nos, spare wheels and tools.... well thats what i put in there anyhow! £250 installed £100 in bits!
Custom fibreglass enclosure really nice build quality covered in matching carpet as the floor pretty heavy so collection only on this one slightly oversize volume for an alpine 12R think its a dual 4 ohm will check though. which is currently fitted which gives a much nicer sound than the recommended volumes which are too small for the type of music i like any how the enclosure is £150 £80 for the sub £200 for both! Worth nothing that this fits over the rear turret and can be removed and installed in 2mins as all connections are on plugs so it can be removed for track days etc
Similar setup with the amp rack which fits on the other turret plywood and fibreglass construction again covered in matching carpet. Removable within 2 mins again same same. Comes fited with the perfect amp to run the sub which is an alpine v12 m605 perfect paring in my opinion. Really good quality £200 for everything wont separate as its kinda made to fit one amp perfectly!
Door pods these are phil-j jobs made of mdf with mdf baffles for speakers really nice fit. Speaker pods only £120
I currently have some hertz HSK 165’s in there which are awesome speakers kinda wasted in a polo but i love music so :p These retail at £250 a pair still got the boxes run in properly come with crossovers and baffles etc looking for £150
Doors have had proper grommets which i stole from a Daihatsu i think so that speaker and central locking cables can be ran through them properly. The doors came of for this and if you are intended on running door speakers this is a time consuming job and will make your life easier if you are painting the car anyway to fit these doors. Also have central locking kit fitted and audi door handles £70 each without central locking kit £25 for central locking gear
Alpine pdx2.150 this is a two channel stackable amp it is class D and is in very good condition £150
Nitrous system. This is a full WON system and is not your average cobbled together bag of shit. This has all uptodate fittings bottle heater custom made mount wiring etc can be provided but to be honest your better of making your own along with all lines your better of buying new to honest. So things included are :
•11lb bottle £50
•bottle heater £150
•Thermostat for bottle heater
• new style bottle valve with safety pressure relive valve which is self sealing unlinke a blow of disc and you wont loose your full bottle of gas when it goes over pressure!£100
•Cross fire injector with a selection of jetting nozzles allowing you to run 5,25,50 and a 70 dependant on mixture £50
•Blanks £5
•Fuel t-piece £10
•All stainless steel fittings compression and two bags of olives £10
•Rpm window switch to allow selection of injection across a certain rpm “window” £35
•Fuel pressure safety switch which stop the system being activated if theres no sufficient pressure £5
•Two double pole relays for switching solenoids £2
•Two serviced and working pulsiods (older style round ones not the new super duper ones) but the seals and seats have been replaced with the new material ones which are not affected by new fuel addatives £150
•Any extras i’ve forgotten! £free
Now if bought in pieces I can get roughly £550 Which i will defy anyone to go and buy all these parts new or in the same condition second hand for if bought as a kit I will let it go for £450 Sounds expensive but if you want it done properly it will cost you more. I will seperate.
Please note that i have been out of "the game" for a while so some prices may be off and room for negotation, however i know how much i paid for the more expensive items and won't be mugged of either!
  • Views 971
Does the fuel pump cradle come with all the mounting rubbers and brackets?
Pics please.
Yes although I replaced them with non vag ones as I had some new ones from cbs hanging about.ill get some photos for you at the weekend
i'll have the rear hoses and the exhaust hangers. also don't suppose you know if the flexi for the exhaust will fit a standard mk2f ? and is it a gt rear axle?
