Taking the mk2 for a long(ish) drive
Hi,
Hope this doesn't make me sound like an amateur but I have been driving my mk2 for over three years now and only ever use it for short journeys in and around town. Tomorrow evening I was planning on driving it up to the midlands, about a 120 mile journey.
I've made the journey in other vehicles however I am concerned that it will out quite a lot of stress on the car, its only a 1ltr, 4 gears
Does anybody make long journeys often? Is there anything I should with the car before leaving? Its very reliable, i've only had one breakdown due to a ht lead snapping and it just flown through its MOT without a single advisory. Any particular driving style I should adopt?
  • Replies 10
  • Views 627
  • davidpant_teg
    davidpant_teg
    By now you have probably done your run to the Midlands without any drama, but just to reassure everyone with a Mk2, I have owned mine for 8 years. For the first 3 years of ownership it did 200 miles a
  • WoodyPolo170893
    WoodyPolo170893
    Thanks for all the advice guys I made the journey without a single problem. It absolutely flew up the motorway and the engine didn't even sound like it was straining. Surprisingly fuel efficient as w
Check the oil, check the tyre pressure and try to stick to 50-60mph
My 6n 1.0 goes about 3,500 rpm at 70-75mph so I imagine with 4 gears that'll be worse.
May or may no have got 90mph out of my 1.0 mk2f the other weekend.
I honestly believe they're amazing little engines, the only thing taking your journey a little uncomfortable would probably be the lack of 5h gear.
Just think what you think might possibly break, and take a spare..
Edited by DeanH
Probably do it a world of good. It'll burn off carbon in the head and remove any unburnt petrol residues from the oil.
If you are carrying a full load the tyres should be pumped up to 26psi front and 30psi rear, if it's just you 23psi all round.
I always carry a spare alternator belt, a litre of oil and more recently a big bottle of water, a 50mm jubille clip, half litre of antifreeze top-up and a small rad weld pack after a heater pipe developed a split.
my 1.0L regularly gets thrashed on its 4 speed box goes well and a great engine
should be fine , is all the servicing up to date etc?
check the oil and coolant levels before you leave both ways , and check your spare tyre is pumped up
It'll be fine. If something breaks, it will be something that would have broken soon enough anyway.
Yeah it should do it a world of good :)
just make sure you have brakedown cover!!! :-D
but as been said just check tyres, oil, coolant levels before you set off.
By now you have probably done your run to the Midlands without any drama, but just to reassure everyone with a Mk2, I have owned mine for 8 years. For the first 3 years of ownership it did 200 miles a day twice a week running from Bala to Redditch and back. has now done 280K miles (engine rebuilt 100K ago) and I use it for virtually everything. It has never let me down. No, its not the fastest car in the world as its a 1.05 litre Polo C, but it does 70 on the motorway up to Birmingham when i go up occasionally and regularly runs to Wrexham, Oswestry for shopping (round trips 60+ miles) and up to Anglesey to visit the family a round trip of 120 miles.Looked after they are absolutely bombproof. If they still made them,I'd have one new.
Edited by davidpant_teg
thats impressive milage, can you tell us any major repairs /parts its had over those miles?
mines done about 190k orig engine but its had a box and alternator , carb and a fair few bits
I made the journey without a single problem. It absolutely flew up the motorway and the engine didn't even sound like it was straining. Surprisingly fuel efficient as well
