Corroded rear arch
My girlfriend's 6n has a badly corroded rear arch I'm thinking if I cut away the rust I could fill the hole in with fibre glass.
  • Views 705
To do it properly, cut the rust out, make a repair panel from decent sheet steel and weld in, smooth off the welds, skim of filler then sand, prime and paint.
I would never consider putting fiberglass into a steel bodyshell, but if you're not fussed about it being a long term solution then go ahead. I spent far too long pulling out fiberglass from my GT's battery tray which had allowed the metal to continue rotting underneath.
If you are using fiberglass, make sure any bare metal is fully treated and coated before laying down your new material.
I would treat all the surrounding areas with a thick dose of Ku-rust then possibly some bitumen paint before i fibre glassed it
I'm going to cut away the rust and put a brand new panel in i have found one on ebay for £35 or there is a company called 'Car Body Panels 4 U' that i have found does anyone know anywhere else i could get a new panel from?
Thanks,
Joe
Euro Carl parts sell panels
Yeah I've looked on there and they don't do a rear arch for a 6n or a 6n2
I think " Bigsexyrob " might know of a supplier ?
Thanks ill send him a PM
