Comet Blue Mk2 Coupe S
A Reg 1984
75k 'GF' 1272cc Engine - partially rebuilt see below
4 Speed Gearbox
Top-fill radiator - new
Aftermarket sunroof
VWII Brakes with 239mm discs
Powerflex Anti-roll bar bushes
G40 Steering Damper
G40 Steering Arms
G40 Track Control Arms
Straight through stainless steel system
Black carpet in good condition
Black headliner uncut - supplied but not fitted
GT Front seats in Grey
60mm lowered front springs and uprated shocks, new top mounts and bump stops
40mm rear lowered springs
New front/rear brake flexi hoses
Its had a respray at some point in its life, the paint is in really good condition!
The following has been replaced on the engine
Crankshaft Seal (Gearbox End) 068103171F
Crankshaft Gasket (Gearbox End) 026103181B
Crankshaft Gasket (Oil Pump End) 052115189B
Crankshaft Seal (Oil Pump End) 068103085E
Oil Pump Drain Pipe Gasket 052115257A
Water Pump Gasket 030121043B or 030121043A
Sump Gasket 032103609B
Sump Washer N0138492
Flywheel Bolts N90206103 x6
Cambelt 052109119
Oil Filter 056115561G
Ignition leads
Spark Plugs
Rebuilt Seat Ibiza Mk1 Distributer and electronic ignition conversion
NOS Alternator
Engine block has been painted blue,
Has a few shell modifications
Crossmember was previously removed for the turbo conversion, a new crossmember has been welded in
Holes made in front valance for intercooler airflow
Couple of minor alterations to front panel to allow radiator to clear turbo that was fitted
Upper bulkhead hole for Mk3 Wiring loom (ecu in rain tray to engine bay)
Battery tray, part of the inner wing and jacking point were all rotten, this has all been cut out and welded up.
Studs welded to rear chassis leg to allow mounting of Mk3 Fuel pump assembely
Mounted gauges in dash.
All rot cut out of the fuel filler area, repaired, epoxy-mastic'd, seam sealed, overpainted and undersealed.
Black Coupe S arches all round, and lower sill trims
Asking price £1,000 no mot - comes on boggo steels
With MOT £1,200
Edited by grungeisdead
  • Replies 11
  • Views 1.3k
Still here guys
Pictures?
750 quid for the next 2 weeks only, comes with all the spares I have for it
With MOT?
Nope
Only selling as we're moving to Leeds and I want to reduce the fleet to save on the logistical nightmare of moving 9 cars
hey man I'm struggling to find pics, i will admit i haven't been on here for years.. the link about leads to a D reg and above you got it listed as a A reg ? point me the right direction someone lol :P
Edited by Dubbeh
That does link to the right thread
just confused me with the D plate .. cheers
The bumper came off a bready I scrapped but I never changed the plate at the time of the photos as It spent its time in the unit. Reg is a728 rbw.
