What is the labour likely to be on this repair work?
As detailed here: http://www.clubpolo.co.uk/forum/index.php?showtopic=336060&hl=
My car has suffered fairly severe damage, and I would like to know what the labour is likely to be like to replace:
Offside front quarter panel
Front bumper
Complete offside suspension
Offside front wishbone
Offside headlight cluster
Radiator
Coolant hoses
Slam panel
Bumper bar
Offside wheel arch splash guard
On top of this some mountings and brackets will probably need to be straightened.
The parts come to over £350 in a combination of new and used from eBay, the car was worth about £1000 prior to the accident, so I'm wondering if I should just call it quits, sell the Polo as a spares car, and drop £1K on another 9N.
I will update this thread when the car has been inspected thoroughly, and will make a new post with an amended list.
Thanks all.
  • Views 539
you can proboably do most if not all of that yourself or with help from a friend with some tools and know how
If you put it through insurance and a their approved repair, they will write it off as the man/hr rate would make it uneconomic to repair
The biggest cost would be any jig work required to straighten suspension mounts etc.
I wasn't going to put it through insurance because I would have to pay my £250 excess, I would lose my no claims, and my premiums would go up massively. As expensive as it may be, it will probably be cheaper in the long run to do it privately.
It sounds like it may be prudent to replace the car... Any idea how much a 2002 9N 1.2 AWY with 127K on the clock would be worth as a spares car? It starts and drives and everything still works. Its just really smashed up on one corner. I was thinking that I might be able to get £350 for it.
Edited by acme15
Here's the dimensions to check if it needs re-aligning 9N Front body dimensions.doc
Unless you break the car for parts yourself you'll be lucky to see any more than scrap value for the car as it is I'd say.
If you're lucky enough not to have bent the chassis legs then repairing the car yourself would be the cheapest option. Especially if you can use salvage parts for the likes of the panels.
I have had the car inspected and the following needs replacing:
- O/S quarter panel
- Front bumper
- O/S headlight cluster
- O/S arch liner
- Radiator
- Slam panel
- O/S lower wishbone
The parts come to a total of around £300, and I can do most if not all of the work myself, on the drive-way.
Thankfully it looks like I wont be waving bye-bye to Moxxi after all. :D
At least, not until July when I will be looking for a new car, but I would rather sell her on, than have her scrapped!!
Edited by acme15
