Rclick Plug N Play kit indicator
Does anyone know how to wire up the rclick plug n play kit so i can get my indicators to flash when i lock my car?
shane
  • Replies 30
  • Views 2.4k
  • If you don't want to cut or splice wires then you can use 2 small female spade connectors and plug them into one of the three pins on the back of the bulb holders. I think these plugs are for tow bar
Connect the flasher output wires from the remote box to the rear light units on the Black/Green & Black/White wires, this will then flash all 6 indicators
Yup, fitted a kit to mine and the instructions show you which wires, just go one to each rear indicator and they will all flash
If you don't want to cut or splice wires then you can use 2 small female spade connectors and plug them into one of the three pins on the back of the bulb holders. I think these plugs are for tow bar wiring?
Ok i will have alook tomorrow and hopefully i get it to work haha, not very good with wiring stuff up or anything so will give it ago.
Thanks again.
Shane
Does anyone have a picture they could show me of where to connect them please?
If you look at the bulb holder unit, on the back there is a two pin connector recessed and a three pin the same, you want the two pin one and if you look closely it's labelled BL (Blinker L ) so on the relevant side put your wire to the BL you'll need a 2.4mm lucar tag, normally used for speaker connections so Halfords sell them
th_10A2D489-F3B7-4B74-A8BE-8C9117027889_
Side do i put both the wires together on a lucar tag mate and put it on just the BL one?
You need the wire that says in the kit left indicator to left indicator feed and the one that days right to the right indicator or only one side will flash if you join them
No, you have the two wires from your new remote unit? then you need to run one wire to each of the rear light units and put the 2.4mm Lucar tag onto the connection marked BL Bear in mind that picture is from a 6N light unit bulb holder, so if someone in the past has fitted 6N2 lights (popular mod) then the connection might not be in the same position, but it should still be marked as BL
Ok mate i kinda understand now, so i need ti extend one of the wires so ut goes to the left holder and have one on the right mate? Does it matter which way they go round?
Unless the new wires from your box are marked L & R then it wont matter, but if they are then connect the one marked Left to the Left light unit & Right to Right
Ok, thanks nige and matt, ill have a go at it tomorrow, thanks for the help, much appreciated
Have been to halfords and got the connectors and fitted them and plugged it into the back of the cluster and it isnt flashing my indicators, am i doing something wrong?
Have you got a multimeter ? if you have connect the positive lead to one of the wires and the other meter lead to chassis and see if you get a pulsing voltage when you lock/unlock, if that's OK you haven't put it on the correct terminal on the light cluster
Ok i will go try that now, thanks
I cabt seem to find a multimetre but i have just had another look andni have a brown wire with a fuse on it, does that have anything to do with the wires? Its begging to irritate me now tbh
Ok I've plugged the brown wire in and it works the drives side indicators but i cant get the passenger indicators to come on, i have tried both wires
Splice your left over indicator wire to the opposite side you have working in the matching slot.
Or as nige says out the indicator on that you can't get going then probe it to find your 12v strobe deed then splice into that wire
Ok mate was thinking i was gons have do that, thanks for your help, much appreciated
Hello again, i still cant manage to get the other indicator to work, the brown wire with the fuse in is plugged into the right bulb holder and thats running the right indicator light but no matter what i try i cant get the left inidcator to work, someone I've even managed to get the brake lights to flash and the right inidactor, I'm really stuck and its fustrating, am i doing something wrong atall?
Is that indicator actually working? If so then try the wire from the right one (working one) on the elf light. Does it work now? If so then try the non working wire on the other light, if that doesn't work then that wire isn't for the indicator.
Are both those wires brown? Usually the flash output is brown. If there is only one wire then you will need a diode one each wire after the joint, otherwise when you indicate you flash both sides.
I have tried everything possible, closeted i got was having both indicators flash, but then when i inidicated the both flash, i have a brown wire with a fuse, a redish pinkish one and i cant remember colour of the other, just i aint no good with electrics and its doing mt head in, does anyone have a picture of wgat they have actually done to get the inicators to flash, that would be a really good help.
Thanks dixy for your reply, ill try and get some pics after work tomorrow
According to the rclick wiring diagrams the two outputs for the indicators are both BROWN wires, so connect one to the left light unit the other to the right unit
The pink wire I think is for the boot popper so if it's connected to the indicator, try holding down the boot release button and it should flash, if so then disconnect and leave to the side.
If there is only one brown then you will need a diode on each wire, it's basically a one way valve, allowing power to the lights but not out of them so the power won't go from left to right.
You can get diodes from maplins or eBay, but will need to be soldered on.
