Rclick Plug N Play kit indicator
I have only got one brown wire, will the diode work then? Cos i know when i connected another wire to the brown one and put the other wire on the other indicator they both worked but when i put my indicators on they both flashed instead of just the one.
Just abit confused cos i dont really work on eelectrics, they aint really my strong point hahah.
  • Replies 30
  • Views 2.4k
  • If you don't want to cut or splice wires then you can use 2 small female spade connectors and plug them into one of the three pins on the back of the bulb holders. I think these plugs are for tow bar
Yes the diode will fix that, they usually give you 2 brown wires and one has a diode on it. I guess rclick just do different ways on certain days :)
Not what you expect when you get something that's supposed to be plug and play really. The pump setup is only fitted to the 6n and 6n2 and both have the same connectors for the indicators, in the same place - so I would have thought they could have supplied the indicator wires already to length and with a connector on it? Or at least the right number of them
This is how to connect the diodes
post-36925-0-78101700-1413712142_thumb.j
Ok thank you nige and dixy for your help, i will have ago at this in thw week hopefully, where can i get a diode from? Thanks
Maplins sell the diodes or have a look on ebay?
Ok i will do, thanks for your help
