Polo 86c 1.3 r6 carbs
hello guys,
I'm from Germany and read lots of English forums to get enough knowledge about a bike carbs set up in a polo.
Cause in Germany aren't any forums about this topic, I hope I get some help here :/
I have a polo 1.3 AAV engine, yesterday I started my project with the yamaha r6 rj03 carbs. Original carbs with the original jets and so on
I can start the engine and drive slowly with half throttle. But when I give full throttle at 2500rpm, I have no power.
It sounds that the carbs don't get enough fuel :/
I have use the stock pump from the polo an in the circle of the in an out line from the pump I have a T-piece with one line into the carbs.
I hope someone can help me.
Thanks Chris
  • Views 1.8k
Tons of information in the bike-carb topic, in the FAQ section.
I've always used the Honda CBR carbs, they've always been good for me, i've heard of people having problems with R6 carbs but i don't know why.
Do you use also only a t piece?
You'll probably need a restrictor in the return line (from the T piece) so that the fuel fills the float bowls properly rather than just returning.
However, as Mikey said, check out the FAQ as there's all the information you'll need in there.
Personally I don't like the T piece method. I would get a motorbike fuel pump. These stop pumping when fuel is at the required pressure. Use the one from the bike the carbs are from
Thanks a lot for these tips :)
The original jets are 150 is this okay ore I need bigger ones?
And where I get the vacuum for the brakes?
Here you can see my work till now. I'm not sure but I thing the position of the T-piece must be over the carbs?
Bit of a random one, but I've been trying to message you and your inbox is full. Any chance you could delete a few old messages?
