Rust Treatment -
I've got a few areas of surface rust on my mk2.
My understanding is that I need to take it back to bare metal, treat it then prime and paint.
What is the best product to use to treat the rust?
Some photos below of the rust.
The second one is on the bottom of the passenger door.
Edited by jacksmartie
  • Views 898
  • Another vote for BH deox gel, also had loads of success with jenolite gel which is phosphoric acid. Neither of these products are "miracle shyte" convertors, you end up with clean although pitted stee
bilt hamber deox gel totaly removes the rust if you can be bothered with a few treatments , better than brush on convertors imo
once its bright clean shiney steel etch primer and top coat it , with the wing check the unseen side is sorted too
Thanks, yeah I want to do a proper job of it. I'll get the wing off to do a good check, previous owner did a questionable paint job on it anyway so maybe this is the time to do the whole wing.
Another vote for BH deox gel, also had loads of success with jenolite gel which is phosphoric acid. Neither of these products are "miracle shyte" convertors, you end up with clean although pitted steel.
Anyone else got any options on rust treatments?
Cut it out and weld in new metal...
I'd just grind/ sand it back to solid metal, skim of filler and away you go.
Edited by MaxVW
I 2nd this as I never looked at photos before ..
