6n2 3dr rear windows glued in or bolted in?
Reason for asking if it's possible is I'd like to swap them out for some tinted windows on a car that's being broke on eBay.
And I can't tell whether the windows are bolted behind the cars trim or whether I'd need to slice them out.
  • Views 651
They are bonded, you need a thin wire/nylon to cut the bonding glue
If you do a search I know I put up the extract from the manual on how to remove them
Brilliant thanks a lot.. I do a search for your topics to try to find it!
