Boot/tailgate strut ball pin come out!
Got a little problem with my boot. Was closing the boot the other day and heard a ping. The pin/ball joint that holds the gas strut to the column had come out. I tried to screw it back on to the column but something on the inside of the column fell down. I have attached a pic of how the hole in the column looks and something similar to the ball joint/pin that I have. Any idea how to get the bit from inside out and how to get it to the right position to screw back in? Thanks for your help.
  • Views 3k
Popular Days
If theres enough meat left where the stud was mounted you could tap an over-sized thread into it, assuming you could get a ball stud to fit it.
Only other way i can think of is to get a riv-nut fitted.
