fother mucking leak!
My beautiful pride and joy 98' 6n pistachio 1.0l open air, well I've had her for 7weeks now and has a leak in the boot, so I siliconed between the bumper and boot and over the back lights (thought it was them as they are 6n2 lights and wernt quite flush) and was fine for 3 weeks so it's been peeing it down in coventry and I just poped into the car to mover her and their is a PUDDLE on my passengers seat and a drip in the back I have wet carpet in the drivers footwell and my boot is wet again! WHAT IS THE DEAL? I'm fed up with silicone and New sills and rubber washers!
So what am I missing? If any of you know what's next for me to try then please speak up before I lose my mind! Thanks :/
  • Views 1k
It's the roof u need to remove it and but a Bead of sealer around the inside edge the fit the roof if u don't do it before u fit it u won't be able to get to the roof behind the motor and it will still leak. It's just one of the joys of owning and open air
dont be using silicone sealer..its not right for the job and water will soon get past it
make sure you find the right place..then use tiger seal
My 6n2 had a lot of water in the passenger footwell, tried for weeks to find where the leak was coming from and it turned out to be a blocked drain hole on the underside of the car, pretty much directly under the passenger seat, it's about a 6mm hole, unblocked that and it was fine.
New leak sprung up yesterday Thanks to the torrential rain we had in Coventry, it's from a completely different place but it still soaks the passenger footwell, yet to figure this one out...
I very much doubt it's from the rear lights as it's in the front footwells. As above I would take the whole roof out and clean and check it and then seal around the cassette and refit.
Also, is that a 1.0 litre open air? Never seen one before, pretty awesome if so.
