6N door cards - fabric paint?
Hi all, I would like to make the horrible looking fabric on my door cards black but unsure the best way to do this, I came across a post by Wilwyn0708 and have pm'd him but in case he's not around here much, could anyone offer any advice on either reupholstery or fabric paint to help point me in the right direction?
  • 3 months later...
  • Views 1.7k
I painted mine black before but away to retrim them in swede and leather.looks more oem and proffesional trimmed
Are yours the black fabric type? Or is it all dark vinyl ?
If it's fabric, then you can remove it quite easily if you heat up the edges where the vinyl meats the material, then lift it gently all the way around. The material is then glued down. If you get the material off in one piece, just flatten it, maybe ireon it? So it's a bit flatter then trace it. Onto your new material and cut it as close as you can. Then just stick it back on.
I started doing this but didn't like it as I used leather, but if you look at similar era golf and passats etc they have lines stitched into them and wading behind it to bulk it up a bit, and also the lower part you rest you arm on is usually a separate piece and would be the only part that's real leather the rest would be vinyl.
Mine is cream coloured so would look okay in one piece, but on a dark grey or black it would look just like the base model panels which are all vinyl if you don't do the extra stitching.
