6N2 GTI buying advice & parts which will need replacement?
Hi guys, so I'm looking at buying a 6N2 GTI 3dr for around the £1500 mark. What should I be looking out for when buying, and what parts will likely need refreshing post-purchase? (I had to do lots of bushes and gaiters and mounts, as well as driveshafts and God knows what else on my 9N straight after purchase)
Any thoughts and advice appreciated. Thanks!
Edited by acme15
  • Replies 14
  • Views 761
Heard these have gearbox issues..?
Anyone?
Gearboxes are made from chocolate! especially on the GTi !! so listen for any abnormal noises and make sure each gear can be easily selected. A drain & refill with quality oil is a good idea
There is a problem with the pedal boxes on these so listen for any creaks or abnormal sounds when depressing the clutch pedal, if you can get under the dash with a torch and look for any signs of cracking around the pivot for the pedals, most were fixed in a recall but some do still have problems.
Bodywork shouldn't be a problem as they were galvanised but a poor repair in the past can lead to corrosion problems.
Electric window switches are a common failure due to water ingress but new ones from VW are around £20 also the wiring between the door and the body can cause strange problems with windows & central locking, the actuator for the fuel flap locking can be a common cause of central locking faults as can water ingress into the central locking pump
Thanks for the info, shame about the gearboxes. I was hoping I was mistaken. :tongue:
What exactly goes wrong with them? Is the work required to fix the issue/damage so much that the bill is painful and it is almost not worth paying for? :-(
Also, are we allowed to post links to Autotrader adverts?
Edited by acme15
How much are pedal boxes to replace?
Can't see there being an issue with posting a link, you're asking for advise.
It's normally the bearings that go, you can get a set off ebay for around £120 then it's down to labour rates to replace them but you'd be looking at a £500 ish bill
if your looking at an ad on autotrader and want general advice then that's OK
The pedal boxes are from memory around £40 from VW and again the biggest bill will be the man/hrs
The gti, is a great car, but yes the gearbox is utter crap... I went threw one almost as soon as I got mine, kinda glad really, they last about 50k miles on avarage I heard. If you can afford it, you could always change to the 6speed from the lupo, but it runs a hydraulic clucth not cable, so its some work...
Iv had a driveshaft and a gearbox mount go on me aswell as a clucth, all relatively cheap fixes tbh.
As for the car, I love it... The little extras make a big difference.
Iv had 126 out of mine, really pushing it and I could feel it, but it wonted to give more lmfao, it accelerates pritty fast aswell.
Just check it over, make sure its running fine (listen closely for knocks in the box) really give it a little beans to make sure its not knocking etc at higher revs..
But the £1500 is about the standard pricing for them, great little car :)
Well you guys have all but scared me off I'm afraid. I would keep it for longer than 50,000 miles with any luck, and the idea of going through two gearboxes in my ownership, as well as other things is a big nahhh.... :tongue:
Oh well... :-(
Hehe, every car has its flaw :)
But yea they are great fun aslong as you look after it
The flaws aren't usually as severe as "munches through a gearbox every 50K" though. :D
get a smart car and do an engine rebuild every 50k :badgrin:
if your prepared to get a gearbox rebuilt and reset the 50k clock you'll have a decent motor you can enjoy for a good few years
Every car has its flaw. But cars that have a bit more performance usually have more flaws to worry about.
This will be down to the mechanicals being more stressed to start with and also they will be driven harder than a normal car.
But whatever you buy for £1500 that is circa 14 years old will have faults or develop some within a year of ownership.
At least if you have something worth the hassle then it will be a bit more rewarding everytime you get it fixed.
But the older cars are easier to work on
i baught a 6n2 for 850.. modified and neglected.. engine was fine after running compression test so decided id take on the project.. full service, belts, pump, sensors here n there, tyres all round. all round discs and pads. window switchs, and now currently looking for window motor haha.. gear box is fine if kept on top of.. and tbh am sure av left a few bits out.. anyway my opinion is if your wanting an old gti.. have relativly ample pockets.. but its worth it in the end :/... lol.... its only money
Found that I can buy and insure a Celica T-Sport for less, and they are very reliable cars. :)
Reliable FWD 190HP sports coupé with VVTLi > Polo GTI :D
Please don't shun me :-(
I STILL LOVE THEM!!!
Toyota-fag stuff below:
This is from a Corolla, but it is the same engine and you can actually hear the lift properly!
https://www.youtube.com/watch?v=Yukzbg1z1Fo
Mockup with wheels & lowering
http://i.imgur.com/UVtUhxI.jpg?1
Mmmmmm, cheap plastic made somehow appealing!
http://i.imgur.com/kjZDz55.jpg
Edited by acme15
