16v 6n fogs
Need help! Bought fogs got a bit of wiring anyone got a Diagrams on how to wire in. Got 2 connectors for fogs then fuck knows where the other bit plugs into :/
  • Views 659
First Welcome to the forum.
There is a guide in the FAQ's at the top of this section. Basically you need to connect the fog light positive supply to the 19 pin light disconnect between the radiator and the battery, the wiring is already there from this disconnect back to the fusebox, then depending on what year you have, you just need to run a wire from the headlight switch back to the fusebox connector, in the FAQ guide it says about fitting a relay but this is not required
This helped loads thank you! Got the wiring all done just need to buy 2 bulbs. And need to get my hands on some torque screw drivers to get bumper off then got to try and fit them. Saw earlier drivers side where the fog fits is half broken. Have you got any photos of them fitted without the front bumper on?
The lights mount on the bumper cover not on the front panel
Just wanted some photos to Help gah
I can dig my spare bumper out and get a pic up later, but they just bolt on in three places two at the top behind the small grilles and one at the bottom from the bottom edge of the bumper, they only go on one way. The wiring originally comes down from the indicator wiring and gors round the back of the openings in the front panel, which is there so you can change bulbs without taking the whole bumper off.
The 8v fog lights fit to the front panel because the bumpers are different and no space to fit them to the metal bit.
Where abouts in Kent you located buddy? I have the torx sockets to get them off if your local.
