snapped cables!
Can anyone help?? I am useless when it comes to cars so need some advice. I have had to change my indicator stalk on my 6n2 polo after lots of swear word later I got the air bag cover off but doing so I have broke the air bag cable off the back of the steering wheels.
What cable do I need to reconnect my air bag??? And roughly how much will it cost??
  • Views 726
Post a photo of the bit you have broken!
PoloD.
I did the same thing. Did the yellow connector come off with the airbag? ...did it take out any of your teeth on the way out? :)
You can get another slip ring from a 6n polo, as they are a bit more common in breakers yards. You will need to take off the 3 small torx screws that you can see when the airbag is off. Then you have to take the wheel off and the black round plastic bit should stay on the column it then plugs in under the plastic cowling
There is a procedure t centre the ring, but basically turn it anticlockwise (I think) until it stops then 2 1/2 turns clockwise is centre then screw the torx screws back on the wheel and refit as one unit.
