Polo Match 2001 Front Bumper Removal Help
Hello,
Wonder if you can help, trying to get front bumper off a 2001 Polo Hatch, have pulled up clips and taken indicators out no problem, undone the four screws in each wheel arch, no problem, taken the grill out and the four bolts, two in each of the centre tops and also took the vents off and undone the screw in each side but there has to be more as it wont come off
where are they as now baffled
any help greatly appreciated
Pete
  • Views 1.2k
theres an extra screw in each wheel arch, need to pull the liner out slightly and its vertical right at the top of the bumper
As above, they're are four in each wheel arch, one is facing the ground
There are also four plastic rivets along the bottom.
