mk4 polo twist headlight removal
Do I have to remove front bumper to remove headlights,tried to replace bulb, old one out ok but new one will not stay jn place,....thanks in advance
What year is the car buddy?
I'm guessing it's a 9n (bug eye type), so you will need to put the bulb in the same way the old one came out. There is a little tab on the bulb and a tab on the holder that need to line up. Then as you turn the holder, use 2 fingers to push the edges of the holder in as you turn it.
Thos headlights are a pita, a simple job that's supposed to take 10 minutes takes a good few hours. You would be surprised at how many people go to garages with the new bulb in hand and in the same boat as you.
