Leaky 6n2 (again!)
Hi, I've got a 6n2 that has a problem with being water tight :(
Another leak has appeared in the last week or so, and every time I turn a sharp corner I can hear water moving about somewhere under the dassboard on the passenger side, if the corner is sharp enough it will all pour out from somewhere behind my glovebox onto the floor, everything that I can feel behind the glovebox is wet so I am at a complete loss as to where it is coming from.
Any ideas are appreciated, it's driving me mad!
Does it have a sunroof?
9/10 it's the drainage tubes being blocked.
Might be an idea to get the glove box off and have a look behind it. It much there that can hold water really, other then the heater box.
That said, it can also be possible for water to come through from the scuttle tray area. If the seal between filter box and metalwork is damaged it would mean water would get through and collect inside the heater box where the blower motor is.
Nope, no sunroof, I cleared out the scuttle tray and drain holes last night and a lot of muck came out, so I'm hoping that will do the trick. If that hasn't fixed it I will take the glove box out, how easy is it to do that?
Also, the seal between the filter box and the bodywork is pretty worn and water is getting into the blower, how would I go about getting or making a new seal?
I can't remember exactly how it comes off, but I think you have to start with the the drivers side lower dash then the central piece then the passengers side. It's all held on with torx screws and is clipped in at places.
If the steel is shot then I would defiantly say it's the culprit.
I would get the filter tray out and remove all the old seal until it just paintwork the use something like tiger seal all the way around and built up a bit so it closes the gap.
Or, if you can find it, there will no doubt be a similar seal you can buy on a roll. If you find this sten clean as above and then stick it down all the way around and fit the tray again.
Hi i had the same problem water splashing when turning and steam coming out of my vent when heat was on the problem was blocked drains underneath the windscreen and the cabin filter was flooded causing water to be dragged through the air vents and leaking in the ducts i took off the plastic and in each end they were leaves blocking the drains remove then and change your pollen/cabin filter (Y) hope this works !
I haven't really had a problem with it since I cleared all of the drain holes out, but if it starts to leak again the seal between pollen filter and bodywork will be the first place I will look. I have the part number for the seal and it's £11 from vw so it's an easy fix.
Thanks for the help!
