Polo 6N 16v Project - Any Recommendations?
Hi all,
In a nut shell, I bought a 16v 6n just over a year ago and absolutely fell in love with it, my romance was short lived when 2 months later, the gearbox failed on me, determined not to sell the car, I was given a fiesta to be able to get to work and the valver just sat on the drive.... until now.....
I've looked long and hard for a replacement 16v gearbox, but could not find a replacement within my budget cheapest I could find was around £450 for a recon'd box, and 3 month warrenty lol.
Doing a little research I found that the only difference between the 8 and 16v box was that the 16v box had a higher gear ratio??, so it wouldn't be as quick off the line as it initially was but should give me more top end, which being completely honest I really don't mind as long as it means I get my baby back..
So, I bit the bullet and ripped an 8v box out a scrappy and re-fitted it.... big mistake.... got a week outa that box, gamble didn't pay off :( but then what do you expect for £40 lol..
So, looking over ebay for box's then a friend suggested a donor car. £120 for an 8v polo with a short list of mot failures, test drove for 40 minutes to make sure box was good, and it was infact turn out the guy was being taken for a run by some local garage saying the water pump had failed, where in reality there was just a small leak in the rad... the one and only major problem...
heres where it gets a little interesting
when i finally got under the new purchase, i realised it was absolutely immaculate, minimal rust for its age compared unfortunaly to my valver.....
new plan???? Engine conversion!!!!!! haha
so last weekend, dropped out both engines and started my conversion, i have already fitted the 16v front subframe, which has a power assisted rack, anti roll bar and bigger discs (thought it would be quicker and easier to swap the hole sub frame rather than the components alone.)
so while the engines out, thought it would be a good idea to service it while its easier to work on...
the rocker gasket needs changing.
also want to renew; plugs, leads, distributor cap and rotor arm,
new oil and filter, fuel filter, timing belt, and air intake will eventually be renewed with a BMC filter.
new anti roll bar bushes and a good general clean up of grease covered components.
inside has been completely stripped ready for the 16v interior
the rear ARB will also be swapped over, coilovers to go on, arches rolled to fit 15" borbets.
6n2 gti rear disc conversion.... so was basically asking if any had any recommendations or ideas for things I've left out??? thanks all, hope i haven't bored the hell outa you :P
  • Views 540
You could bike carb it. If its set up correctly you can get an extra ~20bhp
