mk2 loon project, 1.6 16v with twin carbs, coilys, big brakes....
Mk2 polo saloon project for sale :-(
My beloved Boris has got to go!
Rust free shell with under 80k miles on it
Coilovers all round
Spare set of 60/40 lowering springs and shocks
256mm brakes and uprated master cylinder, all new brake lines, rear cylinders etc etc
1.6l 16v engine, fully balanced, block has been honed and skimmed. 2 heads, 2 sets of cams, pair of original Italian dellorto dhla40's, facet red top pump, filter kings filter/pressure regulator.
This does all need building up, it's all there though, new stretch bolts, bearings, rings just needs a clutch!
Square headlights and grill (very rare!) Set of normal round headlights and matching grill
Original Brown interior
The engine bay has been totally stripped and smoothed then painted metallic gold (sets off really nicely against the Brown)
Ally rad (brackets to mount have already been welded into engine bay)
Probably forgotten loads and loads of bits, been hoarding stuff for this build for nearly 6 years!
£900ono takes it
Needs to go as I'm off travelling soon!
Located just outside of wadhurst, kentpost-22781-0-10843200-1414001979_thumb.j
I'll add a load more photos at the weekend, can't get into my lockup just yet!post-22781-0-10843200-1414001979_thumb.jpost-22781-0-45751600-1414094231_thumb.jpost-22781-0-09608100-1414094246_thumb.jpost-22781-0-70008500-1414094266_thumb.jpost-22781-0-24737300-1414094286_thumb.jpost-22781-0-89284400-1414094323_thumb.jpost-22781-0-08548900-1414094342_thumb.j
Edited by skapunk1
  • Replies 18
  • Views 1.3k
Are the carbs on the car?
Carbs are in the same box as the engine if that counts?
How did you get the 1.6 16v to fit?!
The 1.6 16v isn't a hard job to fit dude. Exactly the same as the afh conversion :) there's a thread to fit the afh so same as that
It's an afh with avy crank conrods and pistons.
trust me it is a hard job haha! the blocks too tall!
How do you mean too tall? Sorry if it seems I'm hijacking this for sale thread but I've done the exact same conversion kike majority of others have now and I didn't have any problem fitting it
would you sell the carbs seperate mate ? thanks
If your using the standard 1.6 Gti engine and not a hybrid of the 1.4 16v then the engine is too tall and protrudes the bay, the only way to get it to work would be to run a dry sump system
urrrr.... no it dont?
Edited by erixtar1992
Price drop!!!!!
£900, this really does need to go soon and I really don't want to have to break him up!
800 for the weekend!
I'll be breaking this next week if it doesn't sell :(
Sorry to keep asking questions mate, but had you sourced a manifold for the carbs? Cheers
I'm a welder/fabricator by trade, was gunna make one.
You can buy them but they look shite, they're too short for max power and they're waaaay too expensive.
Just in case you ask, and I forget the name again, they're made by mangoletsi
The block is exactly the same height as the afh. Anyone one looking at buying this shouldn't be put off by any of the posts by this user. The engine will bolt in to this car fine and without the need for any shallow sump or any other bollocks
Edited by Mclovin
I probably could have made it clearer from the start to be fair. It's an afh block with avy internals.
Have you still got this I'm only down the Road ?
