Mk2F Cup Holders
Can we agree that arguably the biggest negative aspect about the Mk2F is the cup holders, or lack thereof? Have you seen them? They're little tiny indentations in the glove box and whatever drink you put in them will end up splattered across your dash if you take a corner at more than 2mph.
The air vents are far too flimsy to hold any of those cheap plastic things you get at Asda/Halfords, and the windows don't take too kindly to them either. My most successful attempt at a cupholder was buying an adhesive one from eBay and sticking it to the floor infront of my seat. This worked fine until I let a friend have a go at driving, and to describe the physique of this friend we shall use the adjective "big", and... long story short, R.I.P. cup holder.
So now I've resorted to sticking drinks in the door pockets and keeping them upright by either sandwiching them between an umbrella and a plastic gum bottle, or if it's a tall can, using the window winder to anchor it in place. I am getting desperate. Someone give me ideas.
  • Views 2k
This wasn't my idea so I can't take credit for it but, if you have both front seats in the same position you'll fit a drink in between the back adjusters and the seatbelt clips.
I would however like to add there are much more serious things to worry about in a car. Also even newer more expensive cars lack cup holders. My BMW E46 M3 for example...not a cup holder to be found.
Just tried it, but my seat's too far forward and the handbrake gets in the way - and any further back and I'm stretching to reach the pedals.
Why have I been cursed with short legs :crybaby:
Drill two large holes in your glove box...
Problem solved, sort of...
^ He has a point actually, haven't thought of that!
The ones i've seen that look good are the single pop out 6N2 cupholder mounted in either the cubby hole by the cigarette lighter, or the top centre console cubby. However i want to keep the first cubby for my phone, and the second has leccy window switches mounted in it.
Passat B3 or B4 optional cup holders seem to fit to the side of the centre console well in a Mk2f, but these are also very rare.
My preferred option currently is to get a Fischer C-box cup holder like this:
http://www.germansupply.com/home/customer/product.php?productid=17551&cat=387&page=1
And mount that on the passenger side of the centre console. They're well made and as oem as these can get (Fischer made the cassette holder for mk2f's and all other vw's). However these aren't cheap for a plastic cup holder!
Currently i'm using a steel toe cap boot, wedged in the passenger foot well by my rucksack and my mug nestled nicely in the boot!
They do look fantastic but starting at £21 on ebay, wooooow :nea:
Probably the best option though. I suppose I'll start jobhunting... :tongue:
I've made one to fit in by the ciggy lighter for a 6n2 cup holder fits nice and doesnt get it the way when you change gear
I'm not using it anymore as I've got fully stripped now
£15 pm me if you want it
Go to your local breakers yard and have a look at the cars they have, find a good cup holder and take, then butcher it and make it fit.
Pop out ones are cool, and they come in all shapes and sizes, but personally, I hate them because inevitably someone will hit it, and it will snap in half. Usually followed by a nice lengthy argument.
I would go for the sunken in type? Like you see in a fiesta for example, just forward of the gear stick. These would no be to difficult to cut out of the centre console panel and just drill two big holes in your console then slip them in and glue down etc.
Also, you could even go all out and fit a centre arm rest our of a larger car that is deep and ha a holder inside, or a pop out one.
Possibilities are endless really, depends how creative you are :).
